73-87 Chevy _ GMC Trucks => Brakes, Frame, Steering & Suspension => Brakes and Braking Systems => Topic started by: cky686 on April 09, 2008, 11:18:01 pm
Title: No rear brakes.
Post by: cky686 on April 09, 2008, 11:18:01 pm
ok so I have no rear brakes. the rears are drums. iv got new shoes and drums. they are adjusted correctly. and they have been bled. when i press the pedal there is no pressure until the pedal is about 2 inches from the floor then there's a little pressure. im starting to think it might be my master cylinder but im not quite sure.
thanks for your replys.
Title: Re: No rear brakes.
Post by: Fordeatinz71 on April 09, 2008, 11:35:31 pm
sounds like you have either air in the system or a bad M/C.  check your lines to the rear WELL...all the way down the frame.  make sure you don't have a leak or a crimped spot.  you might not be getting enough fluid to the rear to do the deed...
Post by: VileZambonie on April 10, 2008, 06:30:37 am
If everything is as you say, replace the M/C. Make sure you bench bleed it first!
