73-87 Chevy _ GMC Trucks => Body, Glass & Paint => Topic started by: vince311 on April 24, 2008, 11:32:25 pm
Title: Drip rail removal -- how to?
Post by: vince311 on April 24, 2008, 11:32:25 pm
I've searched hi and low for a step-by-step to remove my drip rails....with intentions of putting them back on. Anyone have a resource link or can give advice? thanks for any help.
82 chevy silverado swb
Title: Re: Drip rail removal -- how to?
Post by: 78 BIG TEN on April 24, 2008, 11:39:58 pm
If you are talking about the metal around the side windows, it is very simple to do. I did this last weekend. You will need a 7mm wrench and there are 6 bolts along the rail.
Post by: JJSZABO on April 25, 2008, 07:09:57 am
Not to be a smart :( but, remove the bolts, remove the drip rail, clean up the drip rails, and reinstall using same bolts - simple ;)
Post by: Blazin on April 25, 2008, 09:58:03 am
I always tap the holes back flat before reinstall. It helps keep them from stripping out.
Post by: dumbucket1 on April 25, 2008, 10:07:44 am
On both my 76 silverado and 84 sierra they are riveted on?
Post by: vince311 on April 25, 2008, 10:24:44 am
not to be smart :(  but they are screws...not bolts.
The screws seem to be too long, to both fit in the hole and also miss the stainless molding.
when i unscrew the screws....they hit the inside of the molding before they allow to be angled out. this might require a pic.
Post by: 78 BIG TEN on April 25, 2008, 11:01:48 am
Just got to mess with the "screw" and the drip rail. It will come out, trust me.
Post by: vince311 on April 25, 2008, 11:07:46 am
thanks! indeed....  its one of those things that's overly fussy. easy to scratch the paint, etc. The 7mm open wrench is the key...I did not have one on hand, but picked one up. thanks for the help
Post by: HAULIN IT on April 25, 2008, 03:13:52 pm
Vince, One thing that will help is to pull out on the drip molding once you have the screw/bolts about half way out, this helps with wrench room & once the molding is loose the screws wiggle out easier. Lorne
Post by: alex on April 27, 2008, 09:21:52 am
you should be able to remove the chrome trim from the drip rail;this will expose notches in the mount rail so you can use a socket or a screwdriver to remove the screws ....
Post by: HAULIN IT on April 27, 2008, 09:38:08 am
Alex, Have you had good results putting the chrome back on? Times I've tried to remove it on other vehicles, it kinda rolled, twisted & often times made little ripples, sometimes I could reuse them, but sometimes not. Maybe you have come up with a better way? It is defiantly not needed in this application, just loosen the screws a little starting on one end, pulling out slightly on the molding once it's half way out. I tape the end I start at so it's not flopping around when you get to the last one or two. Lorne
Post by: 80stepsideguy on April 27, 2008, 02:27:11 pm
That doesnt sound right, my 85 cab they were sheet metal screwed on and my 1980 cab they were screwed on as well, sounds like someone riveted them on .
thanks
pat
Post by: dumbucket1 on April 27, 2008, 04:32:05 pm
Hey pat thats possible but one heck of a coincidence...Jeremy
Post by: 80stepsideguy on April 27, 2008, 06:51:22 pm
jeremy,
anything is possible.I use to work at a chevrolet dealership many years ago , working on the GM paint job dilemas and we had a s10 blazer come in and we tried to take the roof rack off cause the collar that the bolt threated in kept turning.well i shortly left after the shop closed down and moved and they went to another body shop owned by the same dealership till their new shop was built and someone tried using them plastic push in clips for licence plates to hold it into place.You never know what some people do to these vehicles to keep them on the road.I could go on and on bout some hack and whack jobs but it be throwing the subject off.
thanks
pat
Post by: 75 C20 on April 27, 2008, 09:24:41 pm
thanks
pat
on my 75 they were actaulyl really cheap plastic and rivited on but on my 79 they are screwed on....
Post by: Blazin on April 28, 2008, 06:38:49 am
73, 74s and some 75s didn't have them from the factory. Sometime along the line there were aftermarket ones offered that were one piece plastic. They were a retrofit type deal for the early ones that didn't have them. I have run across a few sets over the years, they were riveted on.
Post by: Captkaos on April 28, 2008, 09:22:55 am
As Harold stated, all 73-74's and some 75's were actually aftermarket as drip rails weren't offered on these.  The story is one of the engineers that worked on the truck made a set and sold them to GM for a profit and finally in 75 GM started making their own.
Post by: VileZambonie on April 28, 2008, 03:55:51 pm
the ones on my 74 are original ???
Post by: Blazin on April 28, 2008, 06:08:27 pm
Must be special!!! ;D
Post by: Captkaos on April 28, 2008, 06:10:47 pm
Must Be! :D
Post by: 75 C20 on April 28, 2008, 08:54:49 pm
im 99% sure that the plastic ones on my 75 were factory???
the farmer i bough it off of probly would never take the time to put or have them put on
Post by: choptop on April 29, 2008, 07:40:28 pm
Dealer installed option??????
