73-87 Chevy _ GMC Trucks => Wheels & Tires => Topic started by: the dan on May 19, 2008, 12:54:38 am
so im in on the buy of some 20" rims, preferably one of these
(http://static.summitracing.com/global/images/prod/large/ale-875-78512_cp.jpg)
Rim Width (in): 9.00 in.
Backspacing (in): 4.750 in.
Offset (mm): -6.00mm
(http://static.summitracing.com/global/images/prod/large/ale-885-78512_cp.jpg)
Rim Width (in): 8.50 in.
Backspacing (in): 5.671 in.
Offset (mm): +25.00mm
so will both work? im 5/6 dropped and am sure i need the right backspacing to tuck rims, any0one know what i may expect for spaces on either or both?
They should work, most people run 5"-5.5" BS. What size tire are you running? And It is best to look and do all the numbers your self be fore buying wheels..
Trav
i understand, im new to the wheel and tire industry :) ebay seems like the place to get sets of 20" tires for a good deal so ill be doing some research on that, what might you recoment for a tire size?
Here is a like to some tire sizes, 275-45-20 is a good size.
http://www.tirerack.com/tires/Compare1.jsp?width=275%2F&ratio=45&diameter=20&startIndex=0&search=true&pagelen=20&pagenum=1&pagemark=1&RunFlat=All&x=110&y=12
