73-87 Chevy _ GMC Trucks => Engine/Drivetrain => Topic started by: Mamby on May 22, 2008, 02:27:13 pm
Whenever i start my truck up it usually squeals for about a second then it stops, but now, it does it when im driving. I dont think its the belt because ive put belt dressing on it. I think it might be a pulley bearing? any ideas?
it's the belt. get a new one... dressing never works for long.
Ditto, never use dressing, just replace the belt.
Mamby, Yes, change the belt. Also run a piece of 180-220 grit sand paper on the pulley grooves. If the vehicle has been sitting for a little while, a minimal rust build-up can form on the exposed parts & cause the squeal. Lorne
ah, found out what it was, alternator belt was loose, go figure, the only belt i didn't check.
Same thing just happened to me
i just went thru this ordeal 2 months ago;
Not only get a new belt, but get a Gates belt; That Dayco stuff won't cut it.
Please refer to this thread regarding my plight:
http://forum.73-87chevytrucks.com/smforum/index.php?topic=5454.msg26521#msg26521
UPDATE:
Ok, i see it was that the belt was loose. Anyways, i feel my thread is good reading anyways.
Clean the pulleys, sometimes they get oil on them that never goes away on it's own. Loose will do it too ::)
