73-87 Chevy _ GMC Trucks => Performance => Topic started by: mikewb on June 05, 2008, 04:40:03 pm
Title: fuel pump
Post by: mikewb on June 05, 2008, 04:40:03 pm
im switching a throttle body motor for a carb. how should i do the fuel pump?
Title: Re: fuel pump
Post by: Captkaos on June 05, 2008, 04:56:33 pm
The whole engine or just the induction system?
We need more info.  Year truck, current setup etc...
Post by: mikewb on June 05, 2008, 08:09:03 pm
whole motor. its a 90 chevy truck with a tbi. 305 im putting in a 350 with edelbrock carb
Post by: 78 Chevyrado on June 05, 2008, 10:29:09 pm
I'd keep the electronic pumps and put a regulator on it (since it's already there).
Post by: mikewb on June 05, 2008, 11:32:33 pm
i wont have to pull the tank or anything? just run the lines to my carb with a regulator?
Post by: VileZambonie on June 06, 2008, 10:18:26 am
Why not keep it fuel injected?
Post by: Captkaos on June 06, 2008, 11:43:27 am
It would be easier and more economical if the truck is currently setup as a TBI to just drop it in.
If it currently is setup to run a TBI, you are going to have to buy new fuel return/supply lines EFI rated to feed the carb and put a regulator inline.
Post by: eventhorizon66 on June 06, 2008, 01:47:59 pm
Unless its gonna be a hot rod, listen to these guys and keep the TBI.  I have many regrets about the choices I have made for my truck, not the least of which was keepin' it carb'd.
