73-87 Chevy _ GMC Trucks => Wheels & Tires => Topic started by: hotrod24 on June 06, 2008, 07:00:51 pm
hey if andbody has 33x12s on there truck please post pics
Here is a pic of an old blazer I had,33x12.5 R15 BFG mud terrains with a 3' lift as well
yea that is i want and i would like to do it with this
http://www.4wheelparts.com/Lift-Kits-Suspensions-Shocks/2-5-in-Suspension-System-with-ES3000-Shocks.aspx?t_c=1&t_s=38&t_pt=5491&t_pl=1808&t_pn=EXPK1012
about like this
(http://i222.photobucket.com/albums/dd224/74chevy/28b1_1.jpg)
Yeah that should work. 8)
I posted all of our trucks with 33 12.50's. The first one is 16" rim with 4" lift, second is 15" rim with 6" lift, third is 15" rim with 4" lift. I wanted to go bigger on the 6" lift but wouldn't fit in my garage if I did.
them are nice
(http://i6.photobucket.com/albums/y228/Sabaka454/Jecca039.jpg)
hey vile do you have a lift
Yeah 3" lift
would it be possible to have a 2inch lift with 33s i am going for the last pic i posted
Go with a 2.5" lift
front and rear
I do a lot of offroading in the sand and these tires would never work out there with anything less than a 4".
i want be doing any off roading it will be just for looks
ok if i got the kit would it do the front and rear
I purchased the "discount suspension" from 4 wheel parts and it was all Pro Comp stuff, springs and ES shocks. You could always just break out the saw-z-all and bypass a lift kit ;D
how is the kit
well i got it figure i am going for this
http://www.4wheelparts.com/Leaf-Spring.aspx?t_pt=4113&t_pl=1831&t_pn=EXP13311
Dune digger is your black pickup a 4 inch lift? It looks higher than the white one which is a 6 inch lift correct?
