73-87 Chevy _ GMC Trucks => Engine/Drivetrain => Topic started by: buddy84GMC on June 24, 2008, 11:07:57 pm
I have an '84 Sierra with a 72 small block 400 in it and it has HEI. What should the timing be on the balancer for an HEI 400? Mine is about 4 degrees advanced (to the left of the 0) when I put the light on it. I found it to run really good a little above 4 so maybe 5 since the next marker is 6. Let me know if you need any other info to help me out. I am no mechanic but I am trying! Thanks a lot.
Advance the timing to it's full potential. Using the marks and a timing light is good for baselining but you should try to get as much advance out of it without pinging and hard starting.
ya i only us timming lights on smog motors but when the motor starts to grunt when starting just back it off a lil and you should be good
