73-87 Chevy _ GMC Trucks => 73-87 Chevy & GMC Trucks => Topic started by: 8oStEpc10 on July 10, 2008, 03:27:07 pm
Ok yall I did it i had my wing all rebuild and im putting in the last rivet that holds the wing window to the window frame and i bent it....what is the trick to these things? i made the mistake of taking it apart i know that now..what do yall think i should do? :'( ???
I just found 2 posts with this same subject... Why are you spamming the board? You could have just bumped the other one...
I am not sure which piece you bent. Why did you even take the pivot rivet out? How about a picture?
