73-87 Chevy _ GMC Trucks => Engine/Drivetrain => Topic started by: Layne on July 12, 2008, 06:59:42 pm
Title: Aluminum heads
Post by: Layne on July 12, 2008, 06:59:42 pm
Does anyone know where I can get aluminum dart heads for my 305?
Title: Re: Aluminum heads
Post by: lowriderbowtie on July 12, 2008, 08:03:12 pm
buy some 350 ones and have them shaved down
Post by: eventhorizon66 on July 12, 2008, 08:57:37 pm
At one time Trickflow made a set of entry-level heads that fit the 305's bore without any milling.  Not sure of the part number or if they still make 'em.  You'll have to try and contact them.  I'm not sure that aftermarket aluminum heads for a 305 is a good investment, though. :-\
Post by: Layne on July 12, 2008, 10:02:31 pm
I was thinking of putting Dart heads on there. Why would alum heads be a bad idea?
Post by: Unofficial on July 12, 2008, 10:13:16 pm
I'm assuming that it would be a bad idea because putting money into a 305 might be a waste. Most people would probably agree that you'd be better off spending money on a 350. That's just my guess though.
Post by: Layne on July 12, 2008, 10:22:34 pm
I was told it was a 350 till i bought the truck and it's a little disappointing but its my first 8 and I'd like to mod it a tad, nothing serious. lol
Post by: Unofficial on July 12, 2008, 10:25:18 pm
Don't get me wrong, there's nothing wrong with that, That's what I'm doing to the 305 in my '87, I just happened to come across a really cheap 350.
I've got headers and true duals on my truck right now and I don't care how unsatisfying someone might think the 305 is, that thing roars!
Post by: bigkountry on July 12, 2008, 10:27:04 pm
A small cam, headers, exhaust and upgraded carb would be about it for a 305. These little engines aren't made for HP, but I have had a few that would pin the ears back pretty good.
Post by: Layne on July 12, 2008, 10:32:57 pm
All you've said and intake and a serpenine to add and you've got what i'm doing.
Post by: eventhorizon66 on July 12, 2008, 10:41:17 pm
Well you would certainly improve performance on most any engine with a good set of aluminum heads.  But it may not be a very good hp-per-dollar investment with the 305.  First off "there's no replacement for displacement" (I'm sure you've heard this many times before).  Second the 305 has a smaller bore that impedes airflow at the valves and most aftermarket SBC heads are designed for a 4" or greater bore, thus airflow suffers considerably when one mills the heads to fit and slaps them on a 3.74" bore.  In short, the heads cost the same whether they're going on a 305 or a 350 or a 383, but the power will be considerably lower with the 305 compared to the higher displacement 4" bore engines.
For a 305, I'd limit myself to stuff that can be transferred to a 350 later on like intake, headers, ignition, etc.; maybe even a little RV-type cam since they're so cheap.  I guess by this reasoning, you could transfer heads as well, but I'd just hold off on that one.  And don't forget you can see some pretty nifty gains on ignition timing and carb tuning alone, especially if its currently out of tune.
Dang it!  Two new posts while I was typing...man I'm slow.
Post by: VileZambonie on July 12, 2008, 10:41:31 pm
I wouldn't waste that kind of $ on heads either. Headers, cam, intake, ignition otherwise yank it out and put the $ into a 350.
Post by: Layne on July 12, 2008, 10:56:26 pm
Guy i bought it from put a new stock cam in it and when he put the covers on he put the oil cap in and all the other holes on the rocker covers were exposed. so its got a valvetrain clatter and if i gotta fix that it would just make more sense to put a set of assembled heads on her...
Post by: VileZambonie on July 12, 2008, 11:04:36 pm
I can't make sense of what you are saying here. Regardless if you put any heads on it you will have to adjust the valvetrain accordingly.
Post by: Layne on July 12, 2008, 11:12:00 pm
It's got a tick in the valvetrain and I am mechanically inclined enough to do heads, but I can't diagnose the tick and I think some new haeds and a rocker cover set would brighten it up a bit. ;)
Post by: VileZambonie on July 12, 2008, 11:47:00 pm
Why don't re-adjust your valves and see if the tick goes away.
Post by: Layne on July 12, 2008, 11:57:42 pm
Good point. lol never thought of that, and I found those trick flow heads to be $900!!! So I'll probably jus pop the rockers and see what I can do. Thanks
Post by: TexasRed on July 12, 2008, 11:57:54 pm
Perhaps make sure your exhaust is on tight too.
Post by: Dragon on July 13, 2008, 12:49:24 am
Oy Vey! It's all Yiddish to me too, but I will give it a try! :-X  Sounds like the previous owner put back the Oil Cap on the Valve Covers, but left out the Crank Case Breather Grommet,Crank Case Breather,PCV Grommet, and PCV along with the associated Breather Tubes/Hose....  To give you a bit more of assistance, I would suggest you post pics of your Valve Covers, and Engine Bay, so we call help you Identify what all you would need to pick up....
