73-87 Chevy _ GMC Trucks => Body, Glass & Paint => Topic started by: the_legend_1981 on July 18, 2008, 05:04:28 pm
Title: doors hang
Post by: the_legend_1981 on July 18, 2008, 05:04:28 pm
Both of my doors hang a little low in the rear. Should i adjust the hinges or do i need new ones?
Title: Re: doors hang
Post by: joesgarage71 on July 18, 2008, 05:49:13 pm
Bushings on the top hinge need to be replaced. Common on these trucks.
Post by: the_legend_1981 on July 18, 2008, 06:39:13 pm
how do you go about changing these? Where can you find the bushings?
Post by: joesgarage71 on July 18, 2008, 09:20:04 pm
 The top hinge pin is staked you have to remove the door to work on the hinge, leave the hinge bolted to the cab, to get the pin out either grind the bottom of the pin off or cut the bottom off with a cut off wheel.Don't tear up the hinge ginding. Replace the pin and the bushings from the kit. A hinge kit can be had at your local parts store.
