73-87 Chevy _ GMC Trucks => Interior & Equipment => Heating, Ventilation & Air Conditioning (HVAC) => Topic started by: maximus5541 on August 08, 2008, 03:06:56 pm
the a/c in my 83 works. it blows cold, but the problem is it just doesnt blow very hard . i was wondering if there was somethingthat i could clean or replace to fix this problem. i had a friend suggest that i clean the evaporator, but i thought i would ask here before i try anything. also as a side question, when i do trun on the a/c it drags the rpms down very very low????
TTT Does any one have a thought before i start.
If the fan motor is running at proper speeds and there are no obstructions, kinked vents or disconnected vents then clean the evaporator.
thats where i am going to start. i will check the vents and then go to clean the evaporator. Thaks for the help
also, there is a high idle control for the a/c that will kick up the rpms when you turn it on...you may need to replace that or make sure it's hooked up right...
Chuck.
thats what i was thinkin but when i do turn on the a/c the rpms dont go they go down. where would i begin the seach for this high idle switch.
it should be on the side of your carb.
