73-87 Chevy _ GMC Trucks => 73-87 Chevy & GMC Trucks => Topic started by: 8oStEpc10 on August 18, 2008, 03:14:35 pm
OK I have a 80 c/10 stepside and i put new doors on and they were from an 85. I have a new rubber kit for the cab and the glass run seal has two little clips at the top and they dont line up with the holes should i use 81 and up seal or does the 73-80 work?
There are 2 different run channels. 81-91 and 73-80. If your doors are 85, you will want the former to match. The 73-80 will probably work, but....
Window scrapers you will HAVE to get 81-91 versions.
good info to have ;D
What are window scrapers?
The piece running horizontally across the door on the outside and inside (connected to the door panel)
he got it
Hey thanks guys im new at this site and im just trying to get this project off the ground. its my daily driver and someone hit both doors long ago and I just got done prepping the doors shaving them and now pu tting them on and back together so thanks again..
