73-87 Chevy _ GMC Trucks => Engine/Drivetrain => Topic started by: csramsey640 on August 18, 2008, 07:33:00 pm
I had an idea to get most of the fluid from my th400, just wonder if anyone tried it. I was thinking about disconnecting the tranny lines, and installing some small steel to rubber lines. 1 would go in a clean bucket of dex3 the other in a dirty bucket. If needed I have an inline fluid pump that I can use to help with. Then drop the pan and do a filter. ???
If you have never done this before, you can easily make a big mess if you aren't careful.... I would suggest a good Siphoning Pump(Found at any Auto Parts/Hardware/Pet Supply Store) placed down the Trans Dipstick/Filler tube...
(http://i14.ebayimg.com/05/i/000/ff/94/2199_1.JPG)
It's a 6ft Total Hose, but just check it will fit down the tube, or you may need a smalled Diameter Hose(Make sure it is Oil Resistant) found at any well stocked Hardware Store....
A Rinsed Out Plastic Gallon Milk Jug will make a decent fluid carrier, so long as the fluid is not hot....
I usually just drill with a magnet against the drill bit a hole in the torque converter. Then tap it for a pipe plug.
Flushing is unecessary unless the system is contaminated. Periodic drain and fill with a filter change is all you need to do.
