73-87 Chevy _ GMC Trucks => Engine/Drivetrain => Topic started by: 2502 on August 30, 2008, 12:13:26 pm
Title: casting numbers
Post by: 2502 on August 30, 2008, 12:13:26 pm
i've been on google a good bit of the morning and can't seem to find what year application my motor is supposed to be. it'd help since i was replacing gaskets, all i could find was id charts for the casting numbers but they're not listing the year.
it's a 10066036...
any ideas?
Title: Re: casting numbers
Post by: team39763 on August 30, 2008, 01:08:22 pm
I believe Mortec.com has the casting #'s you're looking for.  That's where I go to look up casting #'s.
Post by: 2502 on August 30, 2008, 01:33:07 pm
i did look there, but it didn't list the year for it. unless i'm supposed to assume it's for the 86 above that they listed for the other block ahead of mine.
this is how it reads:
10054727...350...86-up...2 or 4...one piece rear seal, some "Made in Canada"
10066036...350...........2 or 4...Target Master/Goodwrench crate motor, 2-piece rear
                             seal, "Hecho en Mexico"
10066038...350.....92....4...Goodwrench crate motor, 2-piece rear
Post by: HAULIN IT on August 30, 2008, 02:16:43 pm
It would appear that is an "over the counter" GM replacement engine. Not the original one in any GM vehicle. Lorne
Post by: Captkaos on August 31, 2008, 02:23:49 pm
It is an over the counter replacement as Lorne pointed out.  Unless it is a 1 piece rear seal, any pre-86 SBC rebuild kit will work.
Post by: 2502 on August 31, 2008, 02:39:35 pm
i tried gaskets so far for a 80 up til we got to the oil pan gasket, then the gasket from the 77 was the one that seemed to fit. but when we pulled the spark plugs i think that said for a 79. i just wanna save the gas and the headaches of running back and forth to auto zone and not being able to finishs omething one night cuase it's too late and it's closed....
