73-87 Chevy _ GMC Trucks => Engine/Drivetrain => Topic started by: ole blue on September 04, 2008, 06:05:49 pm
Title: quadrajet question
Post by: ole blue on September 04, 2008, 06:05:49 pm
I just bought a 79 seirra grande with a 350 and quadrajet, truck runs great but gets horrible mileage. I cleaned the air filter(k&n) and while it was off I noticed that a larger vacuum outlet(?) at the front of the carb near the top was not connected to anything. I could not find a unconnected vacuum hose anywhere. My question is is supposed to capped off or conected somewhere else.
Thanks
Rod
Title: Re: quadrajet question
Post by: zieg85 on September 04, 2008, 06:32:16 pm
Pretty sure you are looking at the vent tube that would go to the charcoal canister.
Post by: JJSZABO on September 04, 2008, 07:23:13 pm
On mine it goes to the PCV valve and the charcoal cannister
(http://i123.photobucket.com/albums/o317/jjsabol/scan0001.jpg)
(http://i123.photobucket.com/albums/o317/jjsabol/IM0010871.jpg)
Post by: ole blue on September 04, 2008, 08:42:46 pm
So it looks like is should go to the pcv valve.   Thanks im gonna check it out... Will it hurt to not go to anything?
Rod
Post by: jefferias on September 04, 2008, 09:25:58 pm
i have a q-jet as well.   Id say defn hook up your pcv valve should make it run better id think. and if you dont want to hook it up, which i dont reccomend, at leawst plug it off cause your carb will be sucking in un filtered air which is not good. and also put a breather cap where your pcv should be. but again i would just hook it up. hope it helps
Post by: JJSZABO on September 05, 2008, 07:20:27 am
I would recommend hooking up the PVC valve also.  At a minimum, you need to do as jefferias suggests if you don't use the PVC valve.
Post by: Captkaos on September 05, 2008, 08:51:52 am
You NEED a PCV valve or it will find any weak spot and blow all the oil out of it.  If you are running a breather on the valve cover, you should be ok.
