		73-87 Chevy _ GMC Trucks => Interior & Equipment => Instrumentation => Topic started by: maximus5541 on September 17, 2008, 04:29:21 pm
				Since i have owned my 83 swb the voltage has always been very low on the gauge. when i roll the windows up or down ( electric windows) it will draw the gauge all the way to low side in the red. and also if i have the a/c on it will draw the gauge all the way in to the red. this hasnt caused any battery failure yet, but i would like to figure something out before it does happen. i have shaved door handles and key locks, so a dead battery is not something that i want to happen. Does anyone have a solution to this or something in mind for me to check out?
				Test the battery, fully charge it, then test alternator
				Verify the accuracy of the gauge with a meter. If output is low do a voltage drop test on the alternator and battery. If it checks out ok replace the alternator. The field circuit is integrated.
				i used a 95ish alt 97 amp,with a gel cell batt.and also ran 4 gua.amp wire from pos.bat.to pos.bolt on back of the alt .with the stereo blarin 1000 watt amp it stays around 14-15 8).just some ideals hope you figure it out
