73-87 Chevy _ GMC Trucks => 73-87 Chevy & GMC Trucks => Topic started by: Unofficial on October 20, 2008, 10:21:17 pm
Title: Vacuum Leak
Post by: Unofficial on October 20, 2008, 10:21:17 pm
It seems like almost ever since I put in my rebuilt 350, I've had this hissing sound. I replaced the valve covers, so my PCV setup got changed, and now I have a big unused nipple coming out of the TBI spacer ring that the air filter sits on. I got a new spacer without the nipple, and I still have that really bad hissing. I figured I must have some kind of vacuum leak, but I don't know where to start. Is there any special technique or do I just look at every single vacuum line?
Also, I've noticed that sometimes, if I take off from a stop sign or a light, I'll lose all power and it will feel like I'm taking off in too high of a gear. The engine bogs down and I could floor it and it would just chug. Do you guys think a vacuum leak would be associated with this problem, it's getting pretty annoying. Thanks for any help.  :)
Title: Re: Vacuum Leak
Post by: VileZambonie on October 20, 2008, 10:24:57 pm
yep. Use a stethoscope to find the hiss.
http://www.northerntool.com/webapp/wcs/stores/servlet/product_6970_385487_385487
Post by: gerardo0367 on October 20, 2008, 10:45:20 pm
Check the butterfly shafts on the base of the carb i had one that leaked and it had a hissing sound also from worn shafts and or bushings later
