73-87 Chevy _ GMC Trucks => 4 Wheel Drives => Topic started by: icecold on October 25, 2008, 02:21:50 pm
Title: Trouble Steering left?
Post by: icecold on October 25, 2008, 02:21:50 pm
The truck does not turn left all that well. Has a 3inch lift with a normal steering arm. When i got the truck the rag joint was busted and the gearbox was not fully bolted, they said they tried to adjust it i am wondering if they screwed something up in the adjustment, can i adjust the box to fix that? also i plan on getting a 4inch suspension lift with the raised steering arm in the next week or two, this is a project truck so i am not driving it yet just testing it out.
Title: Re: Trouble Steering left?
Post by: VileZambonie on October 25, 2008, 03:08:19 pm
Yes get the steering arm. Make sure you're not hitting the stops but from the sounds of it your drag link is getting bound up.
Post by: icecold on October 25, 2008, 06:35:32 pm
Everything is smooth feeling, it is a new pump and hoses, is there any adjustment on how much it turns left or right on the gear box?
Post by: VileZambonie on October 25, 2008, 10:34:54 pm
No
