73-87 Chevy _ GMC Trucks => 73-87 Chevy & GMC Trucks => Topic started by: kfoz on November 03, 2008, 10:47:25 pm
WHAT MAY BE THE PROBLEM HERE??? MY DRIVERS SIDE FRONT TURN SIGNAL WORKS BUT THE RUNNING LIGHT PART OF IT DOES NOT! THE BULB IS GOOD. MIGHT THERE BE A GROUND ISSUE OF SOME SORT? THE WIRING LOOKS GOOD. ANY HELP IS APPRECIATED!
kfoz
Bust out a test light and check. Do you have B+ at the parking light? If so it is your ground at fault.
