73-87 Chevy _ GMC Trucks => Brakes, Frame, Steering & Suspension => Topic started by: ngarman123 on November 06, 2008, 12:11:05 pm
i cant seem to find sway bar bushings. i need the ones that go through the sway bar and mount it to the axle. all i can find is the ones that mount the bar to the frame!i dont know if they have another name or what but i cant seem to find them. btw my diameter is 1 1/4" if that makes a difference. thanks
What kind of truck? Front or rear?
74 1/2 ton 4x4 front sway bar
is it the sway bar links you need,the ones that almost look like a small shock bushing with a long bolt thru them,if thats them ask for sway bar end links
if you need a break down go to .com and look at the online catalog then from there do a search on swaybar and it should bring up a view that you will recognize and find your part you need just don't order from them right off hand try to look at autozone and what not prices seam to be cheaper if you can find them.
Note: i guess its a bad ideal to list some competition like the one that was up there ^^^. but autozone also has catalogs with the expoded view or at least we did in my store some zoners tho dint know how to use them
Autozone has them in stock on the shelf in greasable urethane bushings here. Check with your local autozone. Otherwise order a set from summit or factory rubber style ones from napa, carquest etc.
