73-87 Chevy _ GMC Trucks => Engine/Drivetrain => Rear Drivelines, Drive Axles and Gearing => Topic started by: worthirt_99 on November 22, 2008, 08:36:31 pm
Title: Standard Rear Axle
Post by: worthirt_99 on November 22, 2008, 08:36:31 pm
Search isn't working. What is the gear ratio for the standard rear axle in 1985 on the c10 with the 305?
Title: Re: Standard Rear Axle
Post by: Captkaos on November 22, 2008, 09:33:40 pm
2.76.
I should have search fixed by Monday.
Post by: 81Cheyenne on November 23, 2008, 10:44:45 am
2.76.
Does that go for a 1981 C10 2wd as well (also standard ratio)?
Post by: Captkaos on November 23, 2008, 07:47:28 pm
pretty much everything 81-up with a 10bolt will most likely have this ratio on it.
Post by: VileZambonie on November 23, 2008, 09:44:55 pm
Most standard common ratio's I've seen are 2.73:1, 3.07:1, 3.08:1, 3.45:1
best way to tell...pull the meatball cover
Post by: Stewart G Griffin on November 25, 2008, 11:54:59 pm
Ugh!  Here we go again.  If it is really is the standard ratio, i would be willing to bet that it's 2.56---nice and stiff.
You could try:
1) There should be a "SERVICE PARTS IDENTIFICATION" decal either on the left inner fenderwell or on the glove box door that should list what ratio you got.
2) You could take your VIN# down to the local dealer's parts dept. and they should be able to look up what ratio came with your truck.
For a very drawn-out, anal discussion of this topic read this:
http://forum.73-87chevytrucks.com/smforum/index.php?topic=3785.0
For some reason, things are always complicated with me;  That's just the way i am, i guess.
Post by: worthirt_99 on November 28, 2008, 08:43:13 pm
I tried number 1 before I asked the question. It didn't tell me much.
Post by: Stewart G Griffin on November 29, 2008, 01:07:51 pm
So, anyways, if it says GQ-1 REAR AXLE- STANDARD on your sticker, then you've got 2.56.
Lowest available for 85 was 4.56, but that, i think, was for 1-tons.
RPO codes for rear axles:
GQ-1   =  2.56
GU-2   =  2.73
GU-4   =  3.08
GU-6   =  3.42
GT-4   =  3.73
GT-5   =  4.10
HC-4   =  4.56
G-80   =  locking diff
i don't claim to be an expert on 73-87 rears, in fact i know very little about differentials in general, but i had to go thru an exhaustive search on what ratio i had in order to get my speedometer calibrated correctly so i could accurately measure MPG.  i confirmed this at the dealer;  If you can find a parts person who likes to talk cars, then s/he is a gold mine.
