Author Topic: 82 truck outside door handle help  (Read 5304 times)
Offline RobertR
« on: December 14, 2008, 05:48:46 pm »
hey guys i have a 82 truck and got some new outside door handles and was wondering if anyone can tell me how to get the rod that connects to the handle off
Offline gbskunk2006
Re: 82 truck outside door handle help
« Reply #1 on: December 14, 2008, 06:31:03 pm »
You will have to remove the clip the holds that rod at that other end.  The clip is hard to describe but if you have a good flashlight you will see how that clip is held in place.  Once that end of the rod is free it can be slide it right out at the handle end and remove the handle.
If you still cannot see how to remove that rod, your local Chevy/GMC dealer should be able to pull up a diagram showing what I've described.
Some figure dexterity here is a real asset :)
Good Luck!
86 GMC C15, 4.3 Litre V6, TH400
http://forum.73-87chevytrucks.com/smforum/index.php?topic=6879.0
90 Toyota SR5 4X4 Ext Cab V6 5 speed
99 Toyota Solara SLE
« Reply #2 on: December 15, 2008, 01:38:16 am »
A small 90 degree pick is a must too.
Offline my1tonrat
« Reply #3 on: December 16, 2008, 06:07:35 pm »
Getting the rod back on can be a major pain, too.  I didn't have the clip, but an hour, a very small nylon zip tie and some long needle nose pliers with bent jaws got it all back together.
Best of luck.
« Reply #4 on: December 16, 2008, 07:13:09 pm »
