Author Topic: 1984 with dual tanks leaks under pressure  (Read 5467 times)
Offline buddy84GMC
    • My Sites on Cardomain
« on: December 21, 2008, 04:24:23 am »
I have an '84 GMC Sierra with dual tanks.  When I use the right tank it leaks when its under pressure after I turn it off for about a minute or 2.  A good bit as well.  The tanks also leak when I fill them but I think its just them being overfilled since nozzles do not even stay in the neck without being held in place.  Different shape I guess but will not stop leaking till it comes down below full tank.  What could be the issue here?  Thanks a lot.  This is scary when people smoke around the truck in the morning at work.  It leaks on stone and dirt so no one can see it!
1984 GMC K1500 8" lift, 39" MT Baja Belted tires, 400 small block
2006 GMC Sierra 1500 SLT 4x4 L33 5.3L Special Edition
1967 Lincoln Continental Coupe Hot Rod, 462 big block
Offline gbskunk2006
Re: 1984 with dual tanks leaks under pressure
« Reply #1 on: December 21, 2008, 05:48:01 am »
Try to narrow down the source of the leak first.  The fact that you mention "pressure" lends me to believe it might be as simple a worn out gas line hose or loose clamp.
If it is a leak in your tank, you're only real option would be to drop the tank(s) after draining, then either use some patching solution or replace it with a new one.  Once the tank is dropped however, you should also check the sending units as well since that might be the source of the problem.
Luckily, when I dropped my tank I already had the truck bed removed so the job of doing so was (I'm assuming) a lot easier.
Good Luck!
86 GMC C15, 4.3 Litre V6, TH400
http://forum.73-87chevytrucks.com/smforum/index.php?topic=6879.0
90 Toyota SR5 4X4 Ext Cab V6 5 speed
99 Toyota Solara SLE
« Reply #2 on: December 21, 2008, 08:31:34 am »
I dont believe it issupposed to be under pressure. Sounds like either a leaking filler hose, or sending unit gasket.
« Reply #3 on: December 21, 2008, 08:34:54 am »
Get a safe light and get under there. You just have to physically look. It shouldn't leak when you fill it either.
Offline buddy84GMC
« Reply #4 on: December 21, 2008, 09:38:45 am »
its definetely not the tanks actually leaking so its a line, hose, sending unit, or the actual cluster of part that switches the tanks.  When they are full it leaks only from the passenger side even if I fill the driver's tank from the whole set up that switches the tanks.  Not sure what that whole assembly is called but thats where its leaking from each time.  Thank for the pointers I will check it out.  The truck is actually in the shop right now so I will see if the bed is off and thats a good time to take care of this.
Offline 78 Chevyrado
  • Z62 ON-ROAD
    • My Photobucket Site
« Reply #5 on: December 21, 2008, 11:10:46 am »
While the bed is off change every rubber fuel line whether it needs it or not, since you dang near cant get to them when the beds on there.   I did that when they had my bed off for paint, I showed up with tools and stuff and was done in 5 or 6 minutes.
Offline buddy84GMC
« Reply #6 on: December 21, 2008, 11:51:09 am »
Thats a good idea.  That about the only rubber that was not replaced on the truck and it looked real bad.  I never needed to use that right tank since I only drove it once a week.  I will just start there.  Still not sure why it leaks when I let the pump automatically turn off but I will tackle that later.  I just never fill it unless I am driving more than 30 minutes to use that little bit up then its safe.  Thanks again
