Author Topic: hesitation/stumble when pushing gas too much in cold weather  (Read 16835 times)
Offline gold84gmc
« on: January 21, 2009, 03:59:32 pm »
i have an 84 gmc with a 350 with a q-jet carb...in cold weather and sometimes in warm weather if i push the gas too much the engine starts to hesitate or stutter and it doesnt want to go unless i let go of the gas some...but if i put it in neutral or park and rev it up its fine...does anyone know what could be causing this
92 buick century custom 3.3L
Offline Blue 82
Re: hesitation/stumble when pushing gas too much in cold weather
« Reply #1 on: January 21, 2009, 05:17:28 pm »
Check your accellerator pump shot
You may not be getting enough at the right time
Offline gold84gmc
« Reply #2 on: January 21, 2009, 05:42:07 pm »
i tried checking that and i can hear and smell the gas but i couldnt see any(i dont know if its becuase i didnt have a light to look in the carb)
Offline Unofficial
« Reply #3 on: January 21, 2009, 07:37:17 pm »
I have the exact problem. It happens very often in the winter and only sometimes when it's warm out. I have a TBI though.
1987 Custom Deluxe R10
350 TBI bored .040 over
MSD ignition
« Reply #4 on: January 21, 2009, 09:29:47 pm »
I think the problem may have to do with the cold engine. Everyone I had would do the same thing until the engine got up to operating temp. The intakes and carbs on these dont seem to atomize the fuel very well when its cold. I figure the tbi would have less trouble, but it does still have to go through the intake. I imagine the fuel condenses in the cold intake. It wont do it in neutral because there isnt much load on the engine. I am not sure of this, its just what I have always thought. Every bigblock I had would not hardly move until it was warn. The small blocks didnt seem as bad, but still did it.
Offline gold84gmc
« Reply #5 on: January 22, 2009, 05:24:59 am »
mine does it even when the engine is up to normal temp....it just does it everytime i drive it in cold weather and sometimes in warmer weather
« Reply #6 on: January 22, 2009, 07:50:13 am »
+2 check timing as well
Offline Unofficial
« Reply #7 on: January 22, 2009, 11:43:17 am »
Again, we have the exact same problem. I'll be up to operating temperature and it will still do it. And just like you, it happens in warm weather, but not as often. Sometimes it will pop and sputter too. You wouldn't think it would do this because I have TBI though...
MSD ignition
Offline gold84gmc
« Reply #8 on: January 22, 2009, 02:08:50 pm »
i know the timing is off but if it was the timing causing this then wouldnt it do it everytime...not just in the cold and sometimes in the warmth
Offline Donut
« Reply #9 on: January 23, 2009, 04:54:11 am »
If your talking last weeks cold, I was hesitating to. :)
I wouldn't rule out the choke either.  Not fully opening or not functioning at all could cause this.  I just hooked mine back up for this same reason.
Could also be icing up on you.
'73 Chevy K-20 ***SOLD***
350/tbh350/np205
'86 C-30 dually, 454/tbh400
Offline gold84gmc
« Reply #10 on: January 23, 2009, 05:43:31 am »
it did do it the worst last week but it does it a lot if its below maybe 40 degrees or so...and does it rarely when its warmer...and i tried holding my choke open while driving because i was thinking maybe the choke is closing but it stays fully open
Offline 82TARDIS
  • PB Blaster Addict
« Reply #11 on: January 23, 2009, 06:38:39 am »
I know I'm a newbie here, but I was having a similar problem back in November with my '82 C10.  I finally found a vacuum line that had slipped off...put it back on, and problem was solved.  Of course, that was on a little 250, but your 350 probably has the same problems, only bigger  ;)
Offline gold84gmc
« Reply #12 on: January 24, 2009, 06:54:34 am »
i looked for bad vacuum lines or ones that fell off and didnt find any....even thought the TRC (throttle return control) has 2 vacuum line connections on it and one of them broke off a while ago...i dont know if thats the problem or not
Offline Prong
« Reply #13 on: January 25, 2009, 04:33:05 pm »
Do you have an open air cleaner? I've found those things are problematic for me in the cold(er) weather.
79 K10 SB 4x4 383/Th350
79 K10 LB 4x4 350/SM465
Offline gold84gmc
« Reply #14 on: January 25, 2009, 05:45:58 pm »
what do you mean?...do i have the lid flipped upside down?....if thats what your asking then no i dont
