Author Topic: np205 4 low problems  (Read 19714 times)
Offline sappy
« on: January 22, 2009, 07:17:32 pm »
on my 76 k20 with an sm465 and np205 tcase, when im wheelin and i put it in 4 low some times it wont compleatly engage it has the low gearing but the front tires dont spin i have to pull it out of 4 low and put it back in a few times for it to engage i have no clue what causes this and or how to fix it, maybe a new tcase? anybody had similar problems with np205? dont particularly want to replace it 205's arent exactly cheap.
Some times it brings joy and sometimes it brings anger but in the end my chevy is better than ford and dodge
Offline cracker0169
    • Myspace
Re: np205 4 low problems
« Reply #1 on: January 24, 2009, 11:50:15 pm »
It sounds like an issue with the shift rails. One rail controls range and the other controls 4wd.
It sounds to me like when you engage low range, the 4wd rail isnt fully engaging (having to try it a few times). You might try to put the transfer in 4hi and crawl underneath and spray both rails with some wd-40 and run the transfer through the ranges a few times.
If nothing else, you could always take the rails out, modify them, and install a twin stick setup. That would give you complete control of your front and rear axle independently. Give you options of Rear Hi&Low, and Front Hi&Low, not to mention it just looks awesome!
http://www.okcnetworks.com/bronco/205/np1.htm
http://www.offroaddesign.com/instructions/NP205%20shift%20instructions.html
1981 K10, 350 - SM465 - NP205 sittin' on 37's
1983 C10, 305HO - TH400
« Reply #2 on: January 25, 2009, 04:13:08 am »
so the 205 ain't bullet proof ??? i don't know crap about them or i would try to help out man but good luck
Offline sappy
« Reply #3 on: January 27, 2009, 07:17:22 pm »
Thats kinda what i was thinking too i just wasnt compleatly sure on it. im with you on the twin sticks im eventually going to get a set because like you say it looks cool and its fun to play with!  ;) and no the 205 isnt compleatly bullet proof i thot the same untill one of my friends blew his up i dont know how he did it he just showed me what was left of the case it was a mess. but thanks for the tip!
Offline joesgarage71
  • Wrench
« Reply #4 on: January 27, 2009, 10:04:50 pm »
One rail controls range and the other controls 4WD
And I thought left one controls the rear output and right one controls the front output
Offline sappy
« Reply #5 on: January 29, 2009, 06:12:40 pm »
im pretty sure that the np 205 doesnt do the front and rear wheel drive option or whatever you want to call it i think it only does range with one stick and 2 and 4 wheel drive with the other im pretty sure you gotta have one of those fancy atlas transfer cases for all the options front and rear wheel drive, range, 2 and 4.
Offline Igosplut
« Reply #6 on: January 30, 2009, 05:27:49 am »
One controls two-to-four wheel drive, and the other controls hi to low range.
  • Wrench
« Reply #7 on: January 30, 2009, 08:21:25 pm »
It does on a NP203 not a NP205 Read this!
Offline sappy
« Reply #8 on: January 31, 2009, 01:54:08 pm »
oh ok that makes much more since then how i was thinking about it. i could see how puting twin sticks would give you the front or rear wheel drive seperate option. just not on the 205 because the way its ingeneered. thanks for all the help and info.
Offline hilton850
« Reply #9 on: February 04, 2009, 02:09:03 am »
I've heard of this happening to 205's when the linkage and/or shift rails get worn out enough.  I like the idea of the twin stick...could probably make your own setup with a little research.
'84 Sierra 3/4 ton.  4 on the floor, 4 wheel drive, upgraded to FM radio and steelhorse seat.  383 stroker under the hood - 430 hp 440 ft-lb.  custom rust holes in the bed and both rockers and cab corners.
Offline sappy
« Reply #10 on: February 05, 2009, 03:22:38 pm »
well that would make since it was a ranch truck for about 20 years and to get in and out of the ranch you gotta use 4 wheel drive. and i do quite a bit of 4 wheelin so its been used to say the least.
