General Discussion
check engine light
Topic: check engine light (Read 7164 times)
Bubba13
check engine light
January 24, 2009, 12:42:18 pm »
On my second truck that I have for my daily driver,( 96 gmc sanoma, 2.2 4 cyl. ) The check engine light went on just shortly after the engine started tapping, not a knock but heavier than a tick. the oil pressure before all this was normal, 20 lbs at idle and 40 on hwy. Now once warm, the oil pressure is 20 hwy and 5 ish at idle. I use mobile clean 5000 oil with a can of Restore in it. The engine light code is " number 4 cyl missfire detected" It's been too cold here to attempt working on it yet. Yea I know it's later than 87 but there has to be some diverse mechanics on here to help. Any ideas will help.
Watch where you're going, remember where you've been...
TexasRed
Re: check engine light
January 24, 2009, 01:23:04 pm »
Probably time for a tune up, plugs and wires.
Bubba13
January 24, 2009, 03:09:05 pm »
changed plugs, still tapping. Also left old plug in block, attached new plug into boot , grounded to block, started engine, have spark, but engine doesnt sound different even with plug there.
frogman68
January 24, 2009, 05:14:26 pm »
Do a compression test
January 24, 2009, 05:40:52 pm »
Unplug the injector connector and see if it has injector pulse using a test light
⌠ŻŻŻŻŻ' [☼===☼]
Bubba13
January 26, 2009, 07:03:29 pm »
sorry, it has a tbi
choptop
Extended cab fanatic
January 26, 2009, 07:28:00 pm »
Almost sounds like a weak coil. Does it have the four pac coil or just the single. You can have a spark outside like you tested, but if it is weak, it wont fire under compression.
January 26, 2009, 08:01:17 pm »
Quote from: Bubba13 on January 26, 2009, 07:03:29 pm
sorry, it has a tbi
You might wanna double check that. You should have SFI not TBI.
Are you hearing a mechanical noise with no load on the engine?
⌠ŻŻŻŻŻ' [☼===☼]
KoolerSL2
Chevy / Ford: A house Divided
January 26, 2009, 08:27:48 pm »
you said 2.2?
almost every 2.2 i see breaks the timing tensioner, which in turn makes a tap louder than a lifter but quieter than a rod.
id check that first.
1985 C10 LWB: gone but never forgotten
1987 R10 LWB: 107k mile near original survivor
2020 Mustang GT: 6sec 1/8mi driver
https://m.facebook.com/pages/category/Automotive-Customization-Shop/HPR-105373468425153/
69byrd
Haulin!
January 26, 2009, 10:28:34 pm »
I had a 97 s-10 with a 2.2 and it done exactly what Chris said, so you might want to check the timing tensioner.
Slade
January 28, 2009, 07:22:48 pm »
Just an observation but I would be very concerned about any engine with only 5lbs. of oil pressure.
Slade
General Discussion
check engine light
