Author Topic: starting on my '78... few ??'s  (Read 36937 times)
Offline frogman68
Re: starting on my '78... few ??'s
« Reply #30 on: January 29, 2009, 05:24:35 pm »
all right guys... i got the front clip off in 1 piece i'm greasy as heck so ill post pics later tonight.
i need some advice on getting the cab off. everything is unbolted and i cannot believe how heavy it is! do i need to take off the doors and all the glass? or should i get 4 or 5 guys to help?? and wheres the best place to grab it from? thanks again, Dennis
I would take the doors and glass out for the weight and also a safety measure
Offline Antti
« Reply #31 on: January 30, 2009, 04:57:18 pm »
And also, the doors weigh pretty much compared to the weight of the whole cab.
« Reply #32 on: January 30, 2009, 09:08:12 pm »
As far as cleaning the frame up Castrol Super Clean works awesome. Wear rubber gloves though, the stuff is pretty potent.
A chain fall and 6x6 with the doors on. I pull them and the seat. Then a 4x4 will cut it.
Offline menace1978
« Reply #33 on: January 31, 2009, 09:34:14 am »
sweet! thank you... yesterday i picked a cabinet sand blaster off craigslist for $80 and played with that cleaning bolts and stuff. did get the driver door off. kind of a pain w/ all the wiring. i'll get the pass. door off today and start cleaning up/removing the mess around the motor... wiring, vaccum lines, brake master, and whatever else i threw on top of there to get the clip and cab off.
pardon my ignorance but what is a chain fall...
2005 pontiac gto/ few goodies... 372 to the tires
1978 chevrolet silverado/ too much to list but not enough!
Offline menace1978
« Reply #34 on: January 31, 2009, 09:53:12 am »
Offline JRConnieK10
« Reply #35 on: January 31, 2009, 10:03:42 am »
Nice progress. Good find on the cabinet also I've been looking for one but I want the bigger one. Does it work pretty good?
'85 K10 LWB 350/SM465
BUILT NOT BOUGHT
Offline menace1978
« Reply #36 on: January 31, 2009, 10:15:41 am »
thanks buddy, i wanted a bigger one also but i figure i'll save anything that wont fit for last and use some cheap home depot sand and do them outside the box and i'm kinda short on room especially when i get the cab, motor and trans out.
it actually works really good. gives my compressor a heck of a work out but i used it on the drivers gas filler tube and the bed bolts and stuff turns out really good. like new!
Offline JRConnieK10
« Reply #37 on: January 31, 2009, 10:42:01 am »
Sounds good. I guess I don't really need it for anything big just never know.
BUILT NOT BOUGHT
Offline menace1978
« Reply #38 on: January 31, 2009, 06:19:26 pm »
so i got the passenger door off today and the cab is still pretty heavy. going to have to get a few friends/neighbors over to help me lift it off the frame.
guy down the street came by and said he doesnt think i should use por-15 on the frame because there isnt any rust. he suggested to powder coat it. what do you guys think?
« Reply #39 on: January 31, 2009, 07:28:41 pm »
First off I would use Chassis Saver over POR15. Same exact stuff but about half the price. POR and Chassis Saver are design to go over tightly adhered rust or sand blasted metal. As far as over paint I have had it work decent over well sanded paint, or lightly sand blasted paint. It needs a mechanical bond just like any coating would. My suggestion would be use Chassis Saver on the rust, an epoxy primer over the paint and Chassis Saver, then spray it with a quality acrylic enamel.
Offline menace1978
« Reply #40 on: February 08, 2009, 05:59:44 pm »
UPADTE: got the cab off yesterday and a buddy brought over a cherry picker for the motor and trans. that cab was HEAVY!! anyways, motor/trans next, suspension and anything else bolted to the frame!
Offline 80stepsideguy
« Reply #41 on: February 08, 2009, 06:08:32 pm »
Gotta love craigslist. Doing some nice work there man Did you use the cherry picker to pull the cab off? I used mine to take my old cab off and put my new 1 on pics:
thanks
pat
1998 Chevy 1500 S/B 2wd
Offline menace1978
« Reply #42 on: February 08, 2009, 06:17:30 pm »
dang! you make it look sooooo easy!! no my dad happened to be over visiting when my buddy came by w/ the cherry picker and i ran over and grabbed my neighbor... so 4 of us. really needed 5 or 6. when i put it back on i'll try that. i am just afraid of breaking/bending/thrashing something.
that frame looks really good from the pics! what did you use on yours??
Offline 2502
« Reply #43 on: February 08, 2009, 08:26:00 pm »
that looks so clean and easy. i'm getting depressed, mine's still sitting with the cab on the frame and a pile of parts.
Offline jay6776
    • Cars I Have Done
« Reply #44 on: February 08, 2009, 08:36:01 pm »
I give it up to u man. That truck is clean if that was mine it would have just been a repaint.
Looks good you going with the same color?
