Author Topic: Z24 Seats  (Read 11926 times)
Offline Jay2D2
Z24 Seats
« on: January 30, 2009, 02:36:03 pm »
Anyone ever try seats out of a Z24 cavalier.. lates 80s style?
Only asking cause I have a nice set and always found them comfortable
Offline 69byrd
  • Haulin!
Re: Z24 Seats
« Reply #1 on: January 30, 2009, 11:07:12 pm »
I had a set in an s-10 they are a real comfortable. I think it would be a good swap.
Offline Dragon
Re: Z24 Seats
« Reply #2 on: February 03, 2009, 01:03:08 pm »
Trying to install them using the stock Cav rails would probably give you a more challenging install, as a Cav has a fairly flat floor since it is a FWD....  You would probably need to fabricate some adapter brackets to use the Cav rails on a Pickup/Crew, but maybe not for a Blazer/some Burbs...   Now with that said, you might be able to get away with redrilling the seat frame mounts, if you were going to use 73-91 Truck rails(Some non truck Buckets will bolt directly to the truck rails no mods needed)...
Dragon
08 Magnum-New Toy
96 Caprice 9C1-Who Knows
96 GMC ECLWB & 92 Chevy ECLWB
Offline 80stepsideguy
Re: Z24 Seats
« Reply #3 on: February 03, 2009, 01:53:14 pm »
I`m using a set from a beretta GTU/GTZ/Z26 but they too got the rails from the floors and i would have to notch the floor in the center for the seat adjustment.I`m gonna fabricate some brackets that`ll bolt to the frame of the seats from a set of buckets i bought off of ebay from a 77-79 truck and they`ll bolt right to the floor.Plus i think summit or jegs sells aftermarket seat brackets so you can bolt your seat to them.IIRC.
thanks
pat
1998 Chevy 1500 S/B 2wd
