Author Topic: hood alignment  (Read 26991 times)
Offline 84chevysilverado
Re: hood alignment
« Reply #15 on: February 19, 2009, 06:57:45 pm »
so do ya think its normal for the hood to stick up like that? what do guys think?
Offline rockable
  • Truckin', like the do-dah man.
Re: hood alignment
« Reply #16 on: February 19, 2009, 07:29:05 pm »
Maybe you need to raise your fender and cowl.   :)
'86 SWB Silverado
Offline ont_guy_38
Re: hood alignment
« Reply #17 on: February 22, 2009, 08:05:28 pm »
the hood is actually adjustable but the way the spring system is on these trucks they are a pain to adjust because when the hinge bolts are loose they actually push the hood all the way up and you get it popping above the fenders...with the hood open loosen the rear bolt on the hinge and push up on the front on the hood and it will move and that should fix your gap..it takes a bit of fooling around to get them right.
