Author Topic: Cam specs on a stock 305  (Read 41064 times)
Offline 85ChevyJRF
« on: February 10, 2009, 11:20:00 pm »
Does anyone know the stock cam specs on a stock 305? And what size cam to go with on a stock motor just to get a thump?
Re: Cam specs on a stock 305
« Reply #1 on: February 11, 2009, 11:11:55 am »
SMALL like less than .400" lift..  I don't remember the exacts though.
You would have to get a cam, lifter and spring set (in my opinion) to go to something with some "thump".
I hear the Thumpr Cams will give the sound though.
Offline 78 Chevyrado
  • Z62 ON-ROAD
    • My Photobucket Site
« Reply #2 on: February 11, 2009, 11:23:54 am »
I've been looking at some cams that thump too.  I'm trying to get the smallest cam I can that you can still hear it.  I have a 350, but the 305 won't be too far off.
For my truck with a 350 I've about got it narrowed down to a comp cams xe262 or xe268.  Here's the specs from Comp:
XE262:
http://www.compcams.com/Cam_Specs/CamDetails.aspx?csid=85&sb=2
XE268:
http://www.compcams.com/Cam_Specs/CamDetails.aspx?csid=86&sb=2
Here's a video of the xe262 in a 350.   being in a 350 means it would be a bit lumpier in your 305.  I'm pretty sure in a 305 I'd get the xe262.
http://www.streetfire.net/video/83-Z28-Cam-idle_99231.htm
Here's a xe268 in a 350, again it would be a little bit rougher in yours.
http://www.youtube.com/watch?v=kukI2LnxrqY&feature=channel_page
I've been looking at the thumpr, and I'm just not sure enough how it would be in a big truck.  it makes good power but it makes it way on up the rpm range.
Here's a thumpr vid for fun  it's in a 350.
http://www.youtube.com/watch?v=j97kabzMOYA&feature=related
All the cars in the videos are idling in park or neutral.  if you have an automatic, when you put it in gear, it will lope even more.
Like capt said, all of these cams require new springs because of the higher lift.  along with the lifters, etc...
« Last Edit: February 11, 2009, 11:45:03 am by 78 Chevyrado »
Offline 82Shortbed
« Reply #3 on: February 12, 2009, 11:37:06 pm »
I sold a guy at work this cam....
Crane 100172
http://www.youtube.com/watch?v=sYMVg2P2LGY
He put it in a 90 Chevy Silverado, swapped it to carb, stock 193 heads.  he said he swapped a set of Z28 springs onto the heads, and is using a performer intake, headers, and a 600 Holley.  wish I had a video of it.  sounds decent.  not too loud though because of the crappy compression.
'82 Custom Deluxe
350, 882s, stock cam...For Now
Offline 85ChevyJRF
« Reply #4 on: February 13, 2009, 02:58:16 pm »
The thumpr in that bel air is what my truck would prob sound like cause i have the same mufflers
« Reply #5 on: February 13, 2009, 03:16:46 pm »
The stock 305 lobe lift was .2484 intake and .2667 exhaust.
Valve lift .373  in .400 ex
Offline 85ChevyJRF
« Reply #6 on: February 17, 2009, 09:51:18 pm »
Thanks Vile
