73-87 Chevy & GMC Trucks
What to build? TH-350 or TH400??
Topic: What to build? TH-350 or TH400?? (Read 7272 times)
idahok1085
March 09, 2009, 12:02:53 am »
Hey guys, My tranny is bone stock I belive, Im running 10" of lift, 40" tires so im wondering If I should do a shift kit in the 350 or swap in a 400?? What do you guys think??
Re: What to build? TH-350 or TH400??
March 09, 2009, 12:12:57 am »
the 400 comes wit OD right? if so go with that to help with mpgs but if you just want to bog go with the 350 also go with a stall converter not sure what range but you should get one to help out
idahok1085
March 09, 2009, 12:18:38 am »
No the 400 is a 3 speed also.
March 09, 2009, 12:36:16 am »
well that blows my suggestion out of the water lol, i'v only dealt with the 350t so im no help
idahok1085
March 09, 2009, 01:10:07 am »
Lol thats alright, I think im going to stick with the 350. Its already here, its not slipping. I think I will do a Transgo shift kit, some stall, tranny cooler, what else is week on these? Should I upgrade the servos?
March 09, 2009, 01:20:59 am »
in my 86 i had a 350t blew it up so a friend had one built and he let me have it, we put it in it Had a shift kit i think 1500 stall man she shifted hard if you got in it. now my rear was all ready week had some play in the yoke but it was still running strong got in it one day going through a puddle i got into it and when she shifted she ended up blowing the rear apart almost put a hole in the differential cover.
idahok1085
March 09, 2009, 01:33:15 am »
Wow. I Just found out doing a VIN decoder that my truck came with a 6.2L Dieasl.
fitz
March 09, 2009, 12:39:30 pm »
Keep in mind that the Turbo 400 uses a different transfer case than a Turbo 350.
75??? franken-trunk
March 09, 2009, 02:29:32 pm »
th400's and much stronger if i were you and im sure that truck sees some muck, th400 with a shift kit and kevlar bands and it would be well worth its money in fun if you get a trans break
and bolt a np205 behind it and your set but avanced adapters makes any adapter you can prolly think of
Jack'em High
Fat chicks can't climb
idahok1085
March 10, 2009, 10:47:56 am »
Yeah you can say I use it for the mud. I already have the 205 TCase. I think for all the work and money I would have to drop to addapt the 400 I should just built the 350. the 350 has a better 1st gear. I have never heard of a trans brake for the mud. I have one in my pro street GN. why the mud?
BlueCollarRon
March 12, 2009, 02:07:20 pm »
Quote from: idahok1085 on March 10, 2009, 10:47:56 am
I have been wonderin that myself
Maybe if u are doing mud runs/drags for time?
or just want to have fun..
82' GMC 4x4 350/350
Motors 1 and 2
http://forum.73-87chevytrucks.com/smforum/index.php?topic=11311.msg83538#msg83538
Motors 3 and 4
http://forum.73-87chevytrucks.com/smforum/index.php?topic=10312.msg148157#msg148157
