Author Topic: Centre Caps  (Read 4875 times)
Offline Laderhosen
'82 3/4 ton, 350, th400,
'88 K5 Blazer, 350, 700R4
’98 BMW 328i daily drive
Offline bmaier
Re: Centre Caps
« Reply #1 on: March 29, 2009, 04:43:42 pm »
Do you have a 2 or 4 wheel drive? If it's 4 wheel it wont fit unless you cut two of the centers out for the front and would also need different lug nuts.
As for whether or not it will fit the stock steels you would have to do some measuring. These center caps may hit that inner dish.
Re: Centre Caps
« Reply #2 on: March 29, 2009, 10:03:34 pm »
You will have to get a set of nuts that have the outer thread on them that fit your wheel studs. I think they will fit then if its a 2wd.
Offline Laderhosen
Re: Centre Caps
« Reply #3 on: March 30, 2009, 03:09:25 pm »
YEah it's 2wd. Was just concerned they might not fit inside the dish.
