Author Topic: 1985 Chevy window removal  (Read 15325 times)
Offline sprice30
« on: March 31, 2009, 04:28:25 pm »
Hey guys. I know this is not really the interior, but I am needing to replace the vent window weatherstripping and the window channel run. Can someone please tell me how to remove the manual windows to put the channel run in? I guess the vent window comes out by taking out the three screws in the top of the door?? Any info would be greatly appreciated. Thanks!
Re: 1985 Chevy window removal
« Reply #1 on: March 31, 2009, 04:39:07 pm »
The door glass comes out buy rolling it down and then removing the vent assembly (2 or 3 bolts across the door frame and one at the bottom under the door panel)
and popping it out of the guide and pulling it out. you many need to loosen the rear track some.
Offline sprice30
« Reply #2 on: March 31, 2009, 04:41:24 pm »
So once I pull the vent window, there is nothing really holding the door window in the track? Just wiggle it out?
« Reply #3 on: March 31, 2009, 04:44:14 pm »
the rollers are holding the track, you have to move the rollers to the opening to get them out.
Offline sprice30
« Reply #4 on: March 31, 2009, 04:46:35 pm »
Ok, thanks Chris. I will check it out.
« Reply #5 on: March 31, 2009, 05:31:26 pm »
Remove the regualr window first completely. Then remove the regulator and then remove the vent window.
Offline sprice30
« Reply #6 on: March 31, 2009, 07:57:35 pm »
I hate to sound stupid, but what is the regulator?
« Reply #7 on: March 31, 2009, 08:54:07 pm »
the mechanism that operates the glass with the crank
Offline sprice30
« Reply #8 on: April 01, 2009, 07:26:56 am »
Ok gotcha, thanks guys!
