Author Topic: pulling while braking  (Read 7798 times)
Offline cwilson jr
« on: April 23, 2009, 01:01:55 pm »
when i am braking the steering pulls to the driver's side.  if i brake with my hand off the wheel it will jerk all the way to the driver's side.  while cruising, the alignment is excellent and really couldn't be any better.  what could this be?
***i forgot to mention as well, the brakes need bled.  the truck stops fine, but i never bled them all the way a while back.  could one line be bled more than th other, and maybe causing a twist while braking?
« Last Edit: April 23, 2009, 01:09:46 pm by cwilson jr »
Re: pulling while braking
« Reply #1 on: April 23, 2009, 01:04:10 pm »
check your brake hoses and caliper slides. Make sure the busing slide freely and the piston can be homed easily. If they check out ok replace both front brake hoses.
Offline Armor
« Reply #2 on: April 23, 2009, 01:41:09 pm »
when that happened to me early on with Blue, i had a lose conection on one of the lines and the one resivoir was empty in the booster, so it could be low fluid, if that helps lol.
« Reply #3 on: April 23, 2009, 05:04:13 pm »
i,v heard of bad brake hoses causing that problem also calibers take the breaks of and check replace pads if needed and go from there
Offline gold84gmc
« Reply #4 on: April 23, 2009, 09:10:31 pm »
i would first check your lines and everything....but i kno of an 89 suburban that was pulling to the right when pushing the brakes and they replaced the whole front end and every part in the front and it was still doing it....and they figured out that the frame was bending or flexing causing the pull
92 buick century custom 3.3L
« Reply #5 on: April 23, 2009, 09:39:25 pm »
Add that garage to the do not call list.
Offline 78 Chevyrado
  • Z62 ON-ROAD
    • My Photobucket Site
« Reply #6 on: April 23, 2009, 11:38:42 pm »
If the brake system hasn't been bled properly there's no reason to expect the brake system to work properly.
