Author Topic: 350 auto  (Read 16075 times)
davlo
  • Guest
350 auto
« on: August 30, 2001, 10:03:00 pm »
have 84 silverado with 350 auto. It leaks from the speedometer cable and the vent in the center of the yoke. I drained it and changed the filter then removed the tail housing and replaced the gaskets , rear seal,speedometer cable and cleaned it up. refilled with proper amount of fluid but still leaks from the same places . what would keep the fluid that high in the tail housing???
j in la
  • Guest
tranny leaks
« Reply #1 on: November 06, 2001, 10:28:00 pm »
i had the same problem with my tail housing.put some silicon in the little hole in the yoke.as for the sppedo cableif the orings are ok and everything tightens up i dont know what else to say without seeing it.how bad is the leak?
