Author Topic: sticky windows  (Read 4701 times)
Offline murraygmc
  • 85 gmc 4x4
sticky windows
« on: June 01, 2009, 09:42:46 am »
iv got crank windows and thay go down bout a inch and stop unless i push down wiyh my hand iv lubed the tracks that worked 4 bout a week so what do i do now ?
85 gmc high serria 4x4
Re: sticky windows
« Reply #1 on: June 01, 2009, 10:02:58 am »
Check the regulator and the seals
Offline oldwhity
Re: sticky windows
« Reply #2 on: June 01, 2009, 08:09:47 pm »
Yeah, what Vile said. Something is obviously binding. Almost sounds like one of the rollers are broken. When you have the door panel off, see if you can feel the rollers in the track and of their broke or not. Good luck.
Rob G.
81 Chevy K20 4x4 LWB stepside
Offline JohnnyMac333
Re: sticky windows
« Reply #3 on: June 02, 2009, 01:02:25 am »
Mine get stuck on the drivers side coming down and going back up, about a couple inches from the top. I've found that if I pull the top of the glass in towards me it goes like it should, like butter. I guess that's not so much an answer of your question which was what's causing it as a way to half-done fix it. But what it seems like to me is that while doing that helps get the window past that sticky spot without any problems, if I hold it like that the whole way, the entire travel of the glass feels much smoother. I've always just attributed it to the geometry of the glass, possibly the geo. of the glass versus the geo. of the door and/or window itself. I dunno. Again, not really an answer. I guess this was kind of a useless post haha.
