Author Topic: Transmisson Question  (Read 4809 times)
Offline unbludictable
  • Low Down Blu
« on: June 11, 2009, 04:38:45 pm »
I have a 350/th350 in my '76 GMC High Sierra. I bought the TH350 from a guy I know and the tranny has preformed well for about a yr now it leaks most of the tranny fluid ove night >:(!
I have changed the gasket twice and it still leaks! An ASC Trained Mechaic friend of mine changed it and IT LEAKED!
My Question: The tranny is Aluminum, should my pan be iron? If not, how can I find the pan to fit my tranny? Or is it the pan?
I read the article on the weep hole I don't know where the fluid is comming from. Help
Re: Transmisson Question
« Reply #1 on: June 11, 2009, 04:45:05 pm »
All the fluid leaking overnight???  That is a bunch, should be fairly easy to find the leak.
Offline eventhorizon66
« Reply #2 on: June 11, 2009, 05:45:33 pm »
Warped pan, rear seal, cracked case.  If you are loosing ALL your fluid, that's easy.  You have a hole in the bottom of your pan. :P
'85 C10 SWB 350 700R4 TKO600
« Reply #3 on: June 11, 2009, 08:42:54 pm »
I just had a TH350 with cronic overnight leakage that I fixed. The detent cable had a pinhole in it and as the torque converter drains there goes your fluid. The speedo, shift shaft seal, tailshaft seal and if it's a C O-ring on the connector are all prone to leakage. If it's the tc seal or pump seal it will be wet behind the converter.
  • Low Down Blu
« Reply #4 on: June 12, 2009, 02:14:35 pm »
Well, I say ALL because when I put it in gear there is not enough pressure to make it change gears! It don't even think about moving. Fluid drips all along the lip of the pan, and I can't tell if it's the pan, gasket, or what! I know what, I have bought 6 gallons of fluid from Walmart at almost $10 each just to see it pissed out on the ground the next day is getting old fast!
Is this an easy fix? Or headache?
« Reply #5 on: June 12, 2009, 02:26:40 pm »
Clean it off. Wipe down the detent cable real good. If it's wet there's a hole in it.
