Author Topic: RE: THE OIL PRESSURE SENDER THING, PART 2:  (Read 3537 times)
Offline Stewart G Griffin
« on: June 14, 2009, 10:04:36 am »
So, how do you know if/when the oil pressure sender thing is in tight enough?
i put thread sealant on and i've got maybe 1,2,3 threads still showing using pliers and it's getting pretty tight to turn.  Also, i noticed that you really can't get a torque wrench on this thing, but even if you could, there's no established torque setting?
Your thoughts?
Re: RE: THE OIL PRESSURE SENDER THING, PART 2:
« Reply #1 on: June 14, 2009, 10:44:36 am »
10lb-ft
Or use German specs - Goodntite
Do not overtighten it
Offline eventhorizon66
« Reply #2 on: June 14, 2009, 11:57:25 am »
I've always used the German specs for anything NPT.
'85 C10 SWB 350 700R4 TKO600
