Author Topic: Intake gasket  (Read 4783 times)
Intake gasket
« on: June 15, 2009, 12:22:27 am »
check this set out at autozone what was someone thinking only putting in one valve cover gasket
Complete set Set supplied with one valve cover gasket due to an OE service procedure stipulating removal of one valve cover to replace both intake gaskets. Includes upper set & PermaDry plus intake manifold gasktes. Permadryplus Premium problem-solving gaskets designed to address sealing problems Features advanced technology impervious to coolant / oils.
http://www.autozone.com/autozone/catalog/parts/partsProduct.jsp?itemIdentifier=615359_97704_2629_&skuDescription=Felpro+/+Intake+Manifold+Gasket&brandName=Felpro&displayName=Intake+Manifold+Gasket&categoryNValue=15399999&sortType=&store=1157&isSearchByPartNumber=false&fromWhere=&fromString=search&itemId=prod60600&navValue=15300526&filterByKeyWord=gasket&productId=615359&appQuestionText=&searchText=gasket&categoryDisplayName=External+Engine&parentId=cat30063&questions=%5B%5D
Offline Jay2D2
Re: Intake gasket
« Reply #1 on: June 15, 2009, 09:33:17 am »
A lot of newer vehicles gasket sets are like this.  Plus you can buy valve cover gaskets  that service just one cover if need be.
Re: Intake gasket
« Reply #2 on: June 15, 2009, 03:55:26 pm »
It says right in the link includes valve cover gasketS
Offline Jay2D2
Re: Intake gasket
« Reply #3 on: June 15, 2009, 08:52:59 pm »
That whole series in Fel Pro MS9800xT are revised GM gaskets to fix the famous GM leaky corners on the OEM gaskets.  they have them for the 3.1, 3.4, 3.8, 4.3 and small blocks.  Last I heard GM had a TSB to replace the OEMS with Fel Pro.  I believe the whole series only comes with one valve cover gasket.
Re: Intake gasket
« Reply #4 on: June 15, 2009, 11:33:47 pm »
it does only come with one valve cover gasket the other one you have to "special order" go figure lol
Re: Intake gasket
« Reply #5 on: June 16, 2009, 04:50:42 pm »
Did you buy one and only get one gasket? If it says valve cover gaskets then they owe you a vc gasket.
