Author Topic: driveshaft length when going from 3spd to th350  (Read 3882 times)
Offline 4chevyman
  • What happens in Brookvegas stays in Brookvegas
« on: June 21, 2009, 07:56:05 pm »
I've got a 76 lwb that had a 3spd and I am thinking about putting a th350 in.  I've got a long tailshaft 350 out of a 78 lwb.  i measured both trans and the 350 was about 3 in longer i think.  anyway i know they are different lengths.  the driveshaft is gone out of the 78, so can i go to the junkyard and get the first section of an auto driveshaft or do i need the whole driveshaft or can i use a shortshaft trans with my manual driveshaft?
Re: driveshaft length when going from 3spd to th350
« Reply #1 on: June 21, 2009, 10:43:33 pm »
I did that very same swap in a 79 I had.  The truck I got the trans out of was a 78 and it had a single piece drive shaft as opposed to the 2 piece with carrier bearing in the 79.  Everything bolted up fine and I was on my way.  I had to tweek the exhaust pipe because it rubbed with the single piece shaft but no biggie.
