Author Topic: Holley or Edelbrock top end...  (Read 6752 times)
Offline 75 C20
« on: July 13, 2009, 07:17:15 pm »
Hopefully in another month or so I am going to purchase either http://www.summitracing.com/parts/EDL-2098/  or this http://www.summitracing.com/parts/HLY-300-503-1/ for my 75's 350 to wake it up a bit. I however cannot decide on which of the two to go with. I have always had good luck with edelbrock but never tried holly so i cant knock it since i havent used it.  The differences I noted are: Holley has timing chain and gears includedeldebrock doesnt, Edelbrock has gaskets included, holley doesnt, Edelbrock heads have 64cc combustion chamber heads and holley has 68. Holley includes pushrods, eldebrock doesnt. Edelbrock includes damper springs, holley doesnt.  Holley doesnt put any numbers on theirs, but edelbrock says 410 hp and 408ftlbs.
What do you guys think would be the better buy, better combo and which one would have more power?
1975 Custom Deluxe 20 350 SM465 2WD Longbed
1979 Custom Deluxe 20 400 SM465 2WD Longbed
1968 Custom Sport Truck 20 327 TH400 2WD Longbed
1985 Silverado 10 305 700R4 2WD Longbed
1969 Pontiac GTO 400 Turbo350
2008 GMC 2500HD 6.0 6spd 4X4 Longbed
Re: Holley or Edelbrock top end...
« Reply #1 on: July 13, 2009, 08:43:31 pm »
Personally I would put my own package together
Offline TexasRed
« Reply #2 on: July 13, 2009, 10:30:29 pm »
How many miles on the engine too?
Offline SUX2BU99
« Reply #3 on: July 14, 2009, 02:56:04 am »
From what you've said, I'd go with the Edelbrock. Their heads and intakes are good proven 'performers' (lol) and the gaskets would cost about what a timing chain and pushrods would. Plus they give some numbers and have a little smaller chambers which is nice if you don't mind possibly running premium gas. One thing though is that published HP numbers like that are dyno numbers taken in absolutely perfect conditions with optimum tuning, no engine accessories that rob power, nice long-tube headers (probably) and straight through free-flowing exhaust, all catered to make the best numbers. It's like the old gross HP ratings of the muscle-car era vs. net HP numbers that we use today.
Offline eventhorizon66
« Reply #4 on: July 14, 2009, 10:47:16 am »
I'm with Vile.  Put your own power package together for alot less.  Better yet, have Vile put one together for you. ;D
I would look towards iron heads.  Even fancy aftermarket iron heads will save you a few hundred.
'85 C10 SWB 350 700R4 TKO600
Offline 75 C20
« Reply #5 on: July 14, 2009, 05:13:58 pm »
60,000
Throw some part numbers out of a wicked package you would throw together if you don't mind.
« Reply #6 on: July 14, 2009, 11:49:04 pm »
Building an engine is like getting a haircut. If it comes out bad you'll be pissed! If it comes out ok you're sorta happy but don't wanna look at it for too long. The big picture is what everyone has a hard time with. Think about your powerplant and your goals. Don't buy a cam because it says EXTREME! or VOODOO! with cool skulls. Don't buy aluminum heads because you heard they are better and so on. Think of what you have as a whole for a drivetrain, compound all of your ratio's and put together a powertrain not just an engine that gives you useless numbers that sounded good in an ad. So if you want helpful input tell us more about your powertrain and your goals.
Offline Donut
« Reply #7 on: July 15, 2009, 07:32:25 am »
I'm in the process of re-doing my top end now.  Shopping around and realizing what I wanted, I ended up with a used set of cast iron vortecs, summit cam, and an e-bay intake.  I don't need HP@5000+rpm, it's a truck that i want to drive.
'73 Chevy K-20 ***SOLD***
350/tbh350/np205
'86 C-30 dually, 454/tbh400
