Author Topic: help deciding carb!  (Read 13174 times)
Offline 83HighSierra
help deciding carb!
« on: July 16, 2009, 06:55:30 pm »
ok in previous threads i was suggest to get a either a holley or edelbrock 600cfm carb. im ready to buy one but im not sure which one to get. if anyone can suggest a certain carb i would greatly appreciate it. a link to it would be perfect. here is all my engine info.
1995-00  350 bored .40 over with one piece rear seal
093 vortec heads with double valve springs
summit stage 3 dual plane intake #226019 non egr
and a th350 tranny
it currently has the carb from my old 305 and just cranks over and dies
any help would greatly be appreciated
Offline fiyaweed06
Re: help deciding carb!
« Reply #1 on: July 16, 2009, 08:06:45 pm »
i personally love the holley 600's
Offline cowboy63645
« Reply #2 on: July 19, 2009, 02:26:51 pm »
Do you need a manual choke or a electric choke?  This is the one I would get:
http://www.summitracing.com/parts/EDL-1406/
I have ran Edelbrock carb's on all of my trucks with great results!  Also, if I am not mistaken, and correct me if I am wrong, but you can probably shop around and find a remanufactured carb for a little cheaper.
Offline rmauto1
« Reply #3 on: July 19, 2009, 08:46:56 pm »
I would totally go with an edelbrock 600 or 650.
« Reply #4 on: July 24, 2009, 09:17:42 am »
ok thanks for the link. i need an eletric choke
« Reply #5 on: August 04, 2009, 06:22:23 pm »
ok so thats the carb i got but yesturday i went to install it and the cables on the right hand side wont connect. they connected to the quadajet but theres no where to connect them on the edelbrock. any help??
Offline eventhorizon66
« Reply #6 on: August 04, 2009, 06:47:52 pm »
??? It should have come with a few studs to bolt to the carb linkage.
'85 C10 SWB 350 700R4 TKO600
« Reply #7 on: August 04, 2009, 08:10:18 pm »
nope... it conly came with a manual and two gaskets.  >:(
« Reply #8 on: August 04, 2009, 09:10:53 pm »
TH350 linkage stud: http://www.summitracing.com/parts/EDL-8018/
Throttle linkage stud rod end type: http://www.summitracing.com/parts/EDL-8009/
Thorttle linkage stud snap on type: http://www.summitracing.com/parts/EDL-8016/?image=large
Try fabricating these pieces or adapting the existing studs from your Q-jet.  It shouldn't be too hard.  Just make sure they are good and secure.
« Last Edit: August 04, 2009, 09:57:59 pm by eventhorizon66 »
Offline TexasRed
« Reply #9 on: August 04, 2009, 09:55:33 pm »
What part of Houston?
« Reply #10 on: August 05, 2009, 07:17:37 am »
thanks, are these the only peices?
northwest houston, in the spring area
« Reply #11 on: August 05, 2009, 12:26:37 pm »
Well you only need one of those two throttle studs, depending on what style cable you have.  Does the cable pull right off or do you have to remove a special clip before removing it?  Look at your Q-jet for a reference.
« Reply #12 on: August 05, 2009, 07:01:34 pm »
[/quote]
o..ok i see. it has the special clip that has to be removed then it comes off, so which of the two studs do i need. heres a pic of the quadrajet before i took it off.. o and my edelbrock doesnt have the little soleniod thing that the red wire is running to on it either.
« Reply #13 on: August 05, 2009, 08:53:13 pm »
If you want to use the Edelbrock stud, it's this one: http://www.summitracing.com/parts/EDL-8009/
But I would replace that stupid cotter pin with a hair pin cotter.
And here is Edelbrock's answer to the idle bump solenoid: http://www.summitracing.com/parts/EDL-8059/?image=large
As you can see, it's expensive, so I would simply fab up a bracket and reuse the factory solenoid.  If you do this, you can also integrate a nice place for the throttle return spring to attach.
« Last Edit: August 05, 2009, 08:59:43 pm by eventhorizon66 »
« Reply #14 on: August 11, 2009, 07:08:44 pm »
ok so i got those two peices and now ive run into another problem... theres only one hole on the carb that i could one of them in..so what about the other peice. i circled it in the pic below
