Author Topic: 6 inch lift.. will 37's fit?  (Read 15149 times)
Offline 76warpig
« on: July 18, 2009, 03:37:12 pm »
Do you guys think a set of 37" TSLs will fit under my burb after a 6 inch lift without rubbing the fenders?  Or do i need a body lift?  I love the suburban forum by the way!!  I will post some pics of my war pig after i get the body line x on and lift installed.  Oh and i need to learn to post pics as well
Re: 6 inch lift.. will 37's fit?
« Reply #1 on: July 18, 2009, 11:16:11 pm »
you need the body lift. with a 6" lift 35 will fit no problem
its kind of hard to read but
http://i333.photobucket.com/albums/m387/rebel_cowboy_83/GeneralMotors.jpg?t=1245234481 thats the link
« Last Edit: July 18, 2009, 11:20:36 pm by Irish_Alley »
Offline Jake_s
« Reply #2 on: September 26, 2009, 09:31:35 pm »
You won't need a body lift if you're not afraid to trim the fenders. i would avoid a body lift on a 'Burb, too much mass to be raised up on 3" pucks.
If you dont want to trim teh fenders, then get a 8" lift and you'll be fine.
Jake
Offline Chevalade
« Reply #3 on: September 27, 2009, 06:11:25 pm »
Trim the fenders, get a set of cut out flares if you really want it pretty. I plan on doing up to 41's with a 6" lift and trimming.
« Reply #4 on: September 28, 2009, 12:52:19 am »
its probably a little more but my fenders are trimmed and rolled looks almost stock well the lip anyway.
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
« Reply #5 on: September 28, 2009, 07:09:51 am »
I hope your rear ratio is like 4.56 or higher number if you wanna put 37's on it.  Those bigger tires KILLS your mpg, as if a sub wasn't bad enough as it is. You'd always have to have the gas pedal mashed to go anywhere--even on the interstate whith those big tires.
I've got 33's on my 3.73 rear 4x4 sub and I am going down to 265's next time i change tires/wheels.
Offline fitz
« Reply #6 on: September 28, 2009, 10:52:39 pm »
My truck had 5.13's to spin the 44" swampers.
