Author Topic: Some 89-91 'Burb questions  (Read 11542 times)
Offline SUX2BU99
« on: September 09, 2009, 05:15:19 pm »
I found a front nose to buy and pilfer for my truck. It's from an 89-91 GMC Suburban, 3/4 ton 4x4 SLT model (top one I believe, it seems to have been pretty loaded). I don't know the exact year but I saw a few interesting things that I thought you guys could answer:
- headlight buckets are chrome around the perimeter but dark grey in the middle including the area between the headlights and parklights. I've seen another GMC Sub in town that had this whole area chromed, like on the Chevys. What is correct? This front end looks bone stock so maybe they changed it someway through or the one I saw in town had replacement buckets?
- there is a fan behind an expanded metal mesh shroud (round) that looked to serve the a/c condenser perhaps. It sorta looks stock and sorta doesn't. It's on the passenger side of the 2 big openings through the rad support. Factory?
- beside this fan, on the driver side of the 2 big openings in the rad support is a stacked-plate cooler of some kind, either oil or trans fluid. Would this also be stock?
Re: Some 89-91 'Burb questions
« Reply #1 on: September 09, 2009, 07:27:29 pm »
I have what you describe on my 85 as far as extra cooling in front of the condenser.  It was an option and stock.
« Reply #2 on: September 09, 2009, 07:28:20 pm »
How bout some pix.
Offline SUX2BU99
« Reply #3 on: September 23, 2009, 12:05:58 pm »
This is from a different Sub but it shows the stacked-plate cooler and the other cooling-looking routing of tubing that is installed under the rad, horizontally. What are they for?
Offline Lt.Del
  • Andy aka:SgtDel
  • DelbridgePhotography.com
    • www.delbridge.net
« Reply #4 on: September 23, 2009, 11:46:13 pm »
that's an oil cooler, i beleive.  I have one on my 91 v2500 GMC sub.  I'll have to look at mine in the a.m. to be sure
« Last Edit: September 23, 2009, 11:50:34 pm by SgtDel »
« Reply #5 on: September 24, 2009, 12:26:13 pm »
Oil cooler as Andy stated.  Part of a towing package most likely.
Offline BLUE BURBAN
« Reply #6 on: January 20, 2010, 11:47:23 pm »
The stacked plate cooler is the engine oil cooler. The other one is the power steering fluid cooler.
