Author Topic: Magnaflow muffler  (Read 4719 times)
Offline dumbucket1
  • Too Many Trucks
  • Coal Hauler
Magnaflow muffler
« on: September 12, 2009, 03:02:10 pm »
87 silverado stock tbi 350. Had a 2 1/2" exhaust made for this truck today. It is two pipes going into the single magnaflow muffler and two pipes exiting the muffler and exiting straight back at the rear bumper through 18" long 4" echo tips. I just wanted to comment that I am dissappointed that the truck is pretty quiet. Should have I gone with two seperate mufflers instead? Do you think this muffler will wear in and get louder? Forgot to mention that I retained the cast iron manifolds and had the cat removed.
Offline eventhorizon66
Re: Magnaflow muffler
« Reply #1 on: September 12, 2009, 04:46:19 pm »
What size case did they use?  That will affect the noise level.
'85 C10 SWB 350 700R4 TKO600
Offline dumbucket1
  • Too Many Trucks
  • Coal Hauler
« Reply #2 on: September 12, 2009, 05:49:02 pm »
The casing is 17" long
« Reply #3 on: September 12, 2009, 06:24:29 pm »
So you've already got the small one for that configuration.
I'd use a dual muffler setup.
The small case mufflers (4" x 9" x 14") were what I used on my old '99 Suburban.  It was a 2.25" true dual with an h-pipe (factory manifolds and cats) and it was plenty loud when you got on it, but mild around town.
They even make (4" x 9" x 11") cases which would definitely up the volume.
Go back and tell them you want your ears to bleed. :P
« Last Edit: September 12, 2009, 06:28:42 pm by eventhorizon66 »
« Reply #4 on: September 12, 2009, 06:40:35 pm »
Actually I take that back.  You don't have the smallest case.  Yours is a 5" x 8" x 18" case, nominally.  This one right (ignore the 3" pipe size - that's their typo)?
Here are two smaller cases:
http://www.magnaflow.com/02product/shopexd.asp?zone=main&id=7998
http://www.magnaflow.com/02product/shopexd.asp?zone=main&id=7996
If you want to save money/space with one muffler try one of these, but I'm still partial to dual mufflers.
« Last Edit: September 12, 2009, 06:42:32 pm by eventhorizon66 »
