Author Topic: How to determine rear end gear ratios  (Read 19865 times)
Offline Robbie
« on: September 27, 2009, 05:55:33 pm »
A few months ago I bought a 1987 Chevy one-ton fleet model R30 truck that had a dump bed installed.  After doing about six weeks of work on it so it would pass Illinois state inspection, I was hauling my fourth load when the right rear axle failed.   I believe it was due to the C clip behind the outer bearing on the brake hub.  Due to the damage that was done, a mechanic friend of mine suggested I replace the rear end rather than try to repair it again.  So, I have put an ad to buy a rear axle assembly on Craig's list.  I have had one reply so far and they question what type of rear axle I have.  I assume they are making a reference to the gear ratios.  I referenced Chuck's Chevy truck site and they reference 3 different gear ratios relating to engine size with transmission type used.  But none of the ratio types indicate a 379 cubic inch V8/TH400 transmission.  All I know that it has a 14 bolt differential with 8 lug hubs and dually wheels.  My question is how do I determine the gear ratio that this is?  Also how much should I expect to pay for a replacement rear end?
Offline Blue 82
Re: How to determine rear end gear ratios
« Reply #1 on: September 27, 2009, 07:01:15 pm »
You can look in the glove box for the RPO codes
G80 - Locking Rear Differential
GT4 - 3.73 Rear Axle Gear Ratio
GT5 - 4.10 Rear Axle Gear Ratio
HC2 - 2.76 Rear Axle Gear Ratio
HC4 - 4.56 Rear Axle Gear Ratio
HC8 - 3.21 Rear Axle Gear Ratio
HE3 - 3.07 Rear Axle Gear Ratio
HO4 - 4.11 Rear Axle Gear Ratio
Offline Blue 82
« Reply #2 on: September 27, 2009, 07:05:59 pm »
Here's some more
4x2, SRW, 3.73 ratio (opt GT4)
4x2, SRW, 4.10 ratio (opt GT5)
4x2, SRW, 4.56 ratio (opt HC4)
4x2, DRW, 10 bolt cover, 3.21 ratio (opt HC8)
4x2, DRW, 10 bolt cover, 3.42 ratio (opt GU6)
4x2, DRW, 10 bolt cover, 3.73 ratio (opt GT4)
4x2, DRW, 10 bolt cover, 4.10 ratio (opt GT5)
4x2, DRW, 10 bolt cover, 4.56 ratio (opt HC4)
4x2, DRW, 14 bolt cover, 3.21 ratio (opt HC8)
4x2, DRW, 14 bolt cover, 3.42 ratio (opt GU6)
4x2, DRW, 14 bolt cover, 3.73 ratio (opt GT4)
4x2, DRW, 14 bolt cover, 4.10 ratio (opt GT5)
4x2, DRW, 14 bolt cover, 4.56 ratio (opt HC4)
4x4, SRW, 3.73 ratio (opt GT4)
4x4, SRW, 4.10 ratio (opt GT5)
4x4, SRW, 4.56 ratio (opt HC4)
4x4, DRW, 14 bolt cover, 3.42 ratio (opt GU6)
4x4, DRW, 14 bolt cover, 3.73 ratio (opt GT4)
4x4, DRW, 14 bolt cover, 4.10 ratio (opt GT5)
4x4, DRW, 14 bolt cover, 4.56 ratio (opt HC4)
4x4, DRW, 10 bolt cover, 3.42 ratio (opt GU6)
4x4, DRW, 10 bolt cover, 3.73 ratio (opt GT4)
4x4, DRW, 10 bolt cover, 4.10 ratio (opt GT5)
4x4, DRW, 10 bolt cover, 4.56 ratio (opt HC4)
4x2, SRW, 3.42 ratio (opt GU6)
Offline Blue 82
« Reply #3 on: September 27, 2009, 07:07:39 pm »
I've had pretty good luck locating parts here:
http://www.car-part.com/
« Reply #4 on: September 28, 2009, 01:12:20 am »
its probably 4.10 or 4.56 when you look at the pinion yoke does it look like you can take like 6bolts off like that? if so you have a 10.5" ring gear if you don't see any bolts its a 9" ring gear next question
does the hubs look like semi floater
full floater.
with out the brake rotors of course. it seams the 10.5" full floater are more than likely 4.10 at least with my experience. but i would pop the cover and look at the numbers should be dana some more numbers then the last 3 sets you use the 3rd and 2nd from last of that set should be something like 55 11 ?? you just take 55/11= about 4.10
