General Discussion
slow window
Topic: slow window (Read 9501 times)
greenmonster
slow window
October 24, 2009, 11:56:49 am »
My passenger side window is slow but if i unplug driver side switch the passenger side moves fast.Any ideas.
Re: slow window
October 24, 2009, 12:43:48 pm »
Resistance.... Do you know how to do a voltage drop test?
⌠ŻŻŻŻŻ' [☼===☼]
greenmonster
Re: slow window
October 24, 2009, 01:09:53 pm »
no I don't
greenmonster
Re: slow window
October 24, 2009, 01:59:09 pm »
I found out th it has to do with the ground wire in the harness.If i unplug the ground the pass side work fast and the driver side works slow and vise-versa with the ground pluged in. Any ideas.
Re: slow window
October 24, 2009, 02:14:16 pm »
Like I said, resistance... You can do a voltage drop test accross the ground side of the circuit from the switch but first check the jumper harness between the door jam in the boot for cracks in the insulation and high resistance. If you find that to be the problem just run a new wire.
⌠ŻŻŻŻŻ' [☼===☼]
greenmonster
Re: slow window
October 25, 2009, 07:12:28 pm »
I still can't figure it out.I have a wiring harness from a 85 and window motors 79 could that be the problem.
greenmonster
power windows
October 28, 2009, 08:36:41 am »
I went from manual to power.The problem is that if I hook up both window switches the windows are slow but if I hook up just one switch,driver or passenger the windows are fast.
Re: power windows
October 28, 2009, 01:55:43 pm »
There is a post on this already, have you done a search?
greenmonster
Re: power windows
October 28, 2009, 10:02:52 pm »
Did a search and couldn't find it.If you know where it is could you send a link.
Re: power windows
October 28, 2009, 10:04:49 pm »
Umm....isn't it your post?
http://forum.73-87chevytrucks.com/smforum/index.php?topic=13929.0
⌠ŻŻŻŻŻ' [☼===☼]
greenmonster
Re: power windows
October 28, 2009, 10:10:22 pm »
Yes it is my post. I must be stupid,I still can't figure it out.
General Discussion
slow window
