General Discussion
power booster issues
Topic: power booster issues (Read 4109 times)
greenkeeper
November 16, 2009, 06:06:41 pm »
Ok, so I recently had to replace my power steering pump on my 87' R-30. Now I suddenly am leaking fluid from the power booster. I checked all the connections and cannot seem to find the leak. Its dripping right onto my manifold causing it to smoke. Is my power booster bad? Just a bad seal? Or do I need to replace it. It is the original to the truck. Any thoughts would be appreciated.
Steve
Re: power booster issues
November 16, 2009, 06:19:07 pm »
So this is a hydro-boost system?
Clean everything off and Check it carefully
greenkeeper
November 16, 2009, 06:33:49 pm »
Yes it is a hydro-boost system. I cleaned it off and checked for leaks. It would appear to be comming from the cylinder on the left side of the power booster. Could I have blown a seal?
November 16, 2009, 06:45:08 pm »
From the accumulator? If so just get a reman unit.
greenkeeper
November 16, 2009, 06:51:03 pm »
Thats what I thought you were going to say. I found one in Middletown for $168.00 Guess I 'll go get it.
General Discussion
