Author Topic: Will a 5.0L injector work ok in a 5.7L?  (Read 60235 times)
Re: Will a 5.0L injector work ok in a 5.7L?
« Reply #15 on: December 15, 2009, 01:22:15 pm »
They are not balanced... They are designed to have a target spray pattern. aside from that they are pulse width modulated by the pcm. The system balances itself. If you are cleaning them, then just clean them and call it a day. If you are replacing them then do yourself a favor and get a tbi rebuild kit while you're at it. You may need one of these too http://cgi.ebay.com/ebaymotors/GM-TBI-Throttle-Body-Fuel-Pressure-Regulator-Spring_W0QQcmdZViewItemQQhashZitem53dd2a5b3aQQitemZ360192826170QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
Offline Skunksmash
« Reply #16 on: December 15, 2009, 08:59:35 pm »
Im kind of intimidated by rebuilding the throttle body. Cause if I screw up then, I have nothing to drive till I get it figured out. I was thinking injectors cause a monkey could replace them in these trucks.
« Reply #17 on: December 15, 2009, 11:18:03 pm »
They are simple to rebuild.  I need to put the article and pictures up in the tech section where I pulled mine down, but they are SIMPLE, there is really nothing to screw up on one.
« Reply #18 on: December 16, 2009, 08:06:01 pm »
Offline Skunksmash
« Reply #19 on: December 17, 2009, 10:28:32 am »
I think that the pics you are referring to have been removed.
« Reply #20 on: December 17, 2009, 10:58:38 am »
I am going to try and upload the article I have this weekend.
« Reply #21 on: December 17, 2009, 12:28:08 pm »
What do you mean they've been removed?
It's just to show you how easy it is to pull apart
Offline Skunksmash
« Reply #22 on: December 17, 2009, 04:43:50 pm »
Think there would be any point in vatting any of that? Or instead just do the rebuild, and maybe replace the injectors, and skip any cleaning/vatting.
Also, I hunted until I found a way to be cheap.  ;D Here is the injector:... ok ...or not. Anyway, you just use that page to select the proper vehicle and engine size and part, and they do have a refurb for the 5.7L for $31 with like a $30 core charge.
http://www.rockauto.com/catalog/raframecatalog.php
And here is the remanufacturing process they put them through. I checked and you just mail in your cores and they credit the card you paid with.
http://info.rockauto.com/GB/Detail.html?83114109.jpg
I called these guys and they said that it's likely that they can even give me a balanced set, all they would have to do is check the specs and pluck a couple of remans that had the same specs after the remanufacturing process. Kinda wonder if it will actually help, but eh, who knows.
« Last Edit: December 17, 2009, 05:15:42 pm by Skunksmash »
Offline Jim Rockford
  • Banned
« Reply #23 on: December 18, 2009, 08:16:29 pm »
I never said GM balanced em, I said its a benefit to sending em off to be cleaned. They get flow tested to see how equal they are.
1973 k20 Camper special
1980 k20 custom deluxe
2004 Crown Vic LX sport
« Reply #24 on: December 19, 2009, 04:34:26 am »
I was replying to the post above mine otherwise I would have quoted you if I was replying to you. Go back and re-read.
Offline Skunksmash
« Reply #25 on: December 24, 2009, 11:43:52 am »
I also came across these babies:
http://cgi.ebay.com/ebaymotors/5235206-5-7L-55lb-61lb-Flow-Matched-TBI-Injectors_W0QQcmdZViewItemQQhashZitem3ca7995134QQitemZ260509880628QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
They might be a safer bet than the other place I found, since the other place would be going out of their way to put together a matched set.
Offline Skunksmash
« Reply #26 on: January 03, 2010, 03:58:07 pm »
Hey vile, what's that thing in this pic? Is that the IAF or IAT (or whatever) sensor?
Offline Layne
« Reply #27 on: January 03, 2010, 04:49:25 pm »
Idle Air Control Valve.
Offline Skunksmash
« Reply #28 on: January 04, 2010, 12:39:46 am »
Cool thanks I still need to replace that thing. Never got around to it, and I'm hoping it can help to cure my rough idle when I do a cold start.
Offline Skunksmash
« Reply #29 on: January 06, 2010, 11:29:21 pm »
Well since my original question has been answered, I may as well use it to go off topic and ask about something else.
I replaced my Idle Air Control Valve, and it seems to have helped. But of course my old plug on the truck cracked and crumbled. So it looks like I'll be buying this:
http://www.oreillyauto.com/site/c/detail/BOR0/PT773.oap?year=1987&make=Chevrolet&model=R10&vi=1059825&keyword=idle+air+control&partType=01517&parentPartType=C0018
All the wires on that are black, and all the wires on mine are color coded. Which method would you use, to make sure you wired it up right? Wrap tape around each one and label it? Also would you just use electrical tape, or would you heat shrink it? I'm going to have to say heat shrink.
