Author Topic: Chassis saver over Bondo  (Read 9446 times)
Offline chronos
« on: December 11, 2009, 10:26:56 pm »
I assume it is no problem painting "Chassis Saver" over Bondo??
Offline 80stepsideguy
Re: Chassis saver over Bondo
« Reply #1 on: December 11, 2009, 10:41:18 pm »
Question is what did you bondo over to use the chassis saver???
1998 Chevy 1500 S/B 2wd
« Reply #2 on: December 12, 2009, 12:12:48 am »
It is made for tightly addheard rust, or sand blasted bare metal. I wouldn't put it over filler. Urethane primer over filler.
Offline chronos
« Reply #3 on: December 12, 2009, 08:04:43 am »
I'm not talking about going over huge gobs of bondo , just skimmed some floor work and was going to chassis saver the entire floor top and bottem
« Reply #4 on: December 12, 2009, 03:30:28 pm »
If you havent bought any of the stuff yet i say go to a local parts store and buy some herculiner bed coating.The stuff is great and i`m using it on the floors of my truck`s cab top and bottom...
thanks
pat
Offline HAULIN IT
« Reply #5 on: December 12, 2009, 05:17:43 pm »
chronos, You'll be fine, the only thing is it will soak into the filler & turn duller when it dries...a second coat will fix that. Lorne
Offline chronos
« Reply #6 on: December 12, 2009, 06:14:38 pm »
Thanks guys , I've already got the chassis saver for my frame and stuff,have enough to do other stuff as well
